What is this brake line called?
    Hey Guys,
    I had a brake line thing completely strip out (yes, I was using a flare wrench) on my passenger side, back drum brake line...
    There's a small hard brake line that goes from the hose, to the drum brake. What is that line called? Where could I get a new one?
    Thanks!
    I'm faster then a prius
    that's a dealer-only part, but i think they are discontinued, but you might be able to see if the parts department can find one for you. Your only other option would be to get it from a junkyard, or make your own - a lot of parts stores have straight pieces of hose with 10mm nuts already installed on it. you would just need to bend it to fit - youd want to get a cheap manual pipe bender wrench to go with it. Exact routing isnt too critical, the new line might be a little too short or too long and may line up differently, but as long as its connected and not interfereing with the wheel, it should be fine.
      Get the brake line tubing and make you own line
      NEW CB
      new
      DARKCLOUD : 90 ACCORD EX MRT
