Go Back   CB7Tuner Forums > 4th Gen-eral > Off Topic
Old 01-10-2018, 08:28 PM   #1
chi
CB7tuner Member
chi is cool... so far.
Things that make you cringe
Before i start,this thread is intended for automotive horror stories. Things you've ran across working on cars,things you've seen happen to cars,etc.
Now I've got a ton of these here stories but the worst one was yesterday. Realized that i never drained the oil in my accord while i was taking off the dizzy for the 3rd time so i could get to the rocker arm assembly..anyway,i threw the pan under the car and cracked open the drain plug. As the oil came out,i about passed out from the intense smell of kerosene almost. No biggy,just some old oil. Then as i layed there watching in horror,the oil slowly started getting lumpy,then i heard a could slight tings in the bottom of the pan. I lit a cigarette and waited for it all to drain so i could investigate wtf the tinging noise was...i emptied the oil pan in our recycle container and to my disgust,i saw metal shavings
Still havent found what they're from,dont even wanna know. All i know is i need to do a swap now and that sucks since i was just gonna daily it lol oh well,life happens
chi is offline   Reply With Quote
Old 01-10-2018, 11:08 PM   #2
fleetw00d
Contributing Member
Back in about 1982, I bought a 1966 Buick LeSabre for $225 while I was between cars. 340 cu. in V8, odometer said 67k, I suspect it was 167k, rusty, paint was shot, but it ran well. After getting my brand spanking new 1982 Chevrolet Citation X11 (not really a bad car at all), I kept the Buick as a winter-beater. I was out slinging it around on dirt/gravel roads one day seeing how must dust I could kick up. I pulled into a driveway to turn around, backed up, then hit the accelerator and the rear end of the car moved about a foot to the right - not because it lit up the rear wheels and was fishtailing - but because the left lower control arm for the rear axle ripped out of the frame allowing the left end of the axle to pivot forward pushing the rear of the car to the right.
__________________
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 254,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 171,151 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114 RIP
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
07 Element EX AWD 175,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 01-11-2018, 12:05 AM   #3
toycar
CB7tuner Member
toycar is very helpful toycar is very helpful toycar is very helpful
Crankshaft endplay.
When building an engine, if you realize there is too much end play = start over
__________________
Quote:
Originally Posted by wed3k View Post
toycar is offline   Reply With Quote
Old 01-11-2018, 03:46 AM   #4
Raf99
Gold Member
Raf99 is very helpful Raf99 is very helpful
haha, hearing a noise coming from the front and feeling a vibration. Get out to realize i forgot to tighten / torque the lugnuts and the wheel was about to fall off Meanwhile 2min earlier i was doing 40 down the road.
Old 01-11-2018, 06:06 AM   #5
chi
CB7tuner Member
That sounds similar to what i did to this 86 chevy k10 i had in school. Pulled out of a hay field i was bailing and punched it,as soon as i did i heard a loud pop then grinding. The entire left side rear axle broke apart and slid out. Good thing it was the hay field behind my parents lol.
I've also forgot about double checking my lugs after doing the brakes on my exes car. She called over her way to work and said the car was shaking so bad that she couldn't drive it. I went to check it out,jacked the car up and wiggled both front wheels and the lugs were barely hand tight lol i felt like an idiot for that one
Old 01-11-2018, 09:13 AM   #6
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
Being on I85 inside the perimeter (if you have ever been in Atlanta, you know what I'm talking about) and having the balljoint break lose in a car in which you're the passenger in, while in the middle lane, waiting for a HERO to come and praying that no one decides to rear end you.
Seeing a bunch white smoke coming from the exhaust in your rotary powered vehicle = rebuild time.
__________________
sonikaccord is offline   Reply With Quote
Old 01-11-2018, 12:56 PM   #7
Bunta
CB7tuner Member
Bunta is cool... so far.
When I first got my car I drove it around pretty gently just trying to figure it out but one day I was on a dirt road and noticed that in turns in one direction the car would rotate extremely well while turns in the other direction felt...weird. On my way back I would hear a rubbing sound from a tire when braking. I took it easy on the way home and when I got out I noticed my driver side wheel was more forward in the wheel well than the passenger side. I put the car on jack stands to find out that the bolt that holds the radius arm in place was missing.
Bunta is offline   Reply With Quote
Old 01-11-2018, 02:34 PM   #8
bassrock234
CB7tuner Member
bassrock234 is cool... so far.
I saw a lot a cringey stuff working at Toyota. Mostly people with springs cut so much there was only a coil or two left.
The worst I think was when I first got my cb7, someone had removed the passenger front brake caliper and shoved a self tapping screw into the brake line to keep it from leaking. The sad part is it worked.
__________________
I wish I could trade my heart for an extra liver, just so I can drink more and care less.
bassrock234 is offline   Reply With Quote
Old 01-11-2018, 08:01 PM   #9
fleetw00d
Contributing Member
Quote:
I had the left front wheel come off a 1995 Ford F150 while driving, lost the wheel/tire in a corn field until I had light the next morning.
Old 01-11-2018, 10:20 PM   #10
F22Chris
CB7tuner Member
F22Chris is very helpful F22Chris is very helpful
Any half assed ďmodificationsĒ done by fanboys who later pass on that itís okay to do. Thatíll make anybody cringe.
Personally, my mom in law when she got the Scirocco. She didnít wait for me to go with her, and she took my better half instead to follow her home. The timing was off like 10 teeth so it ran a little hot & misfired. One of the shift linkage arms were bad causing her to lose 1st, 2nd, 5th, and reverse after it popped off.
She couldnít find the link that popped off, so she popped the clutch all the way home in 3rd & 4th ruining the clutch lol.
I guess the cringe was me fixing silly mistakes? Yeah. Stupid avoidable shit makes me cringe.
__________________
F22Chris is offline   Reply With Quote
Old 01-12-2018, 01:08 PM   #11
AccordWarrior
Guy Smiley
AccordWarrior is very helpful AccordWarrior is very helpful AccordWarrior is very helpful
Back in 2001-2 when washer jet LEDs were all the craze I wired a set into my Accord.
Wire from battery through firewall to switch. Switch through firewall to LEDs, wire from LEDs to ground.
Notice any issues there? Oof.
AccordWarrior is offline   Reply With Quote
Old 01-12-2018, 03:44 PM   #12
toycar
CB7tuner Member
This made me cringe
__________________
Old 01-12-2018, 04:30 PM   #13
AccordWarrior
Guy Smiley
Quote:
Originally Posted by toycar View Post
This made me cringe
I've since gotten significantly better.
Fuse Panel by Mike M, on Flickr
Old 01-12-2018, 04:58 PM   #14
verothacamaro
Contributing Member
verothacamaro is cool... so far.
Send a message via AIM to verothacamaro
Quote:
LOLOL
That must've been disconcerting, but probably expected.
__________________
14 Ford Focus ST - stock(ish) - E30 Tune + Green Filter =
verothacamaro is offline   Reply With Quote
Old 01-12-2018, 05:14 PM   #15
AccordWarrior
Guy Smiley
I always weirdly dug the X-11. IIRC it was quite good at SCCA racing and I read that compared to other cars of its day, it was reasonably fast for what it was. I thought Chevy did a good job with the exterior considering what they had to work with.
Old 01-12-2018, 05:40 PM   #16
toycar
CB7tuner Member
I would have to say so. Nice work. Clean install for sure
something else that made me cringe today:
Wife threatened a craigslist ad if I don't get one of my cars out of the garage so she has a place to park.
__________________
Old 01-12-2018, 06:27 PM   #17
fleetw00d
Contributing Member
If I remember correctly, at the time it was the second fastest car through one of the car magazine's slalom behind the Corvette. I had a lot of fun with it on the back roads of southern Indiana. There was one particular tight correctly banked turn followed by a short passing zone - I was running behind a Z28 Camaro and was able to time things correctly to run much faster through the turn than he did, then jump around him in the passing zone. He tried, but couldn't pass me for the next 10-15 miles.
Edit: My son was showing pictures my mom must have sent him - found this one (winter of 82-83?):
Can you get off topic in an off topic post?
Old 01-12-2018, 11:52 PM   #18
F22Chris
CB7tuner Member
I had to google the x11 because I didnít know it existed. (Born in 92í so that might be cringe worthy in itself to some)
I love the styling on those! The hatch is like GM made an S2 Scirocco, and the notch back looking one looks amazing as well. Reminds me of those older 633csi BMWís from the rear.
And on topic - lime green paint. Ew.
__________________
Old 01-13-2018, 12:16 AM   #19
Losiracer2
CB7tuner Member
Losiracer2 seems to have made some friends!
Send a message via AIM to Losiracer2
I had to replace these on a person's Silverado who complained of a vibration when hitting the brakes. The embarassing thing is, I work at Federal Mogul Motorparts, in braking. We make Moog, Fel-Pro, champion, National, Ferrodo and Wagner products to name a few. This person could've easily bought some replacement parts for cheap using our employee discount for pretty cheap but they neglected to do so.
What brake pads? haha
__________________
member's ride thread
97' Lexus LS400 295k miles.....Luxury Cruiser DD
89' SEi Coupe 42k miles one owner museum find
89' Accord SEi
Losiracer2 is offline   Reply With Quote
Old 01-17-2018, 05:53 PM   #20
oni_cb7
CB7tuner Member
oni_cb7 is cool... so far.
Closing frameless doors by the glass instead of the door body. IT'S INFURIATING.
oni_cb7 is offline   Reply With Quote
