Go Back   CB7Tuner Forums > 4th Gen-eral > Off Topic
Old 08-23-2018, 01:52 AM   #1
thepowderblue
CB7tuner Member
thepowderblue seems to have made some friends!
Send a message via AIM to thepowderblue
Thumbs up Free cb7 shell
Hey guys,I am looking for someone who will breath life back into my white cb7. Its been sitting in a friends back yard for a few years, I want to pull the motor so I can put it into my other cb7 because the h22 has a knock and I want to get one of my cbs back on the road.i was hoping if I gave the car to Someone they will pull the motor for me in exchange for the shell.. I don't have any good pix of it and I am having a hard time using photobucket on my phone right now otherwise I would post pictures.
It's a white 90 ex with a nice red interior with black leather door panels. The body is really straight there are a few spots where the paint peeled so a little surface rust is showing on the roof, its missing the wiring harness for the drivers door and the e brake handle. I started to do a bb6 center counsel conversion and it has a jdm cluster with a 6750 redline.it has black housing headlights and the tail lights are tinted.it is located in Chandler az
thepowderblue is offline   Reply With Quote
Old 08-23-2018, 10:21 AM   #2
Ralphie
Stalker
Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed.
If I was even remotely close, I would help you out.
Ralphie is offline   Reply With Quote
Old 08-24-2018, 08:45 PM   #3
AZaccord
CB7tuner Member
AZaccord is cool... so far.
Send a message via AIM to AZaccord
too bad, I don't have a tuck or trailer to haul it.
__________________
Head light service and grill service avable PM me for info for head lights most year and make. i now do valve covers
(\__/)
(O.o )
AZaccord is offline   Reply With Quote
Old 08-26-2018, 09:56 AM   #4
thepowderblue
CB7tuner Member
Old 09-30-2018, 11:15 PM   #5
thepowderblue
CB7tuner Member
Now that i have time i will post the pictures.
I am looking for someone who will tow it out of my friends backyard where it had sat. I'm pretty sure it needs a fuel pump, and i want the motor and tranny out of it. If someone is willing to drag it out and pull the motor for me as i need it for one of my other cb7s they can have the shell. i have the leather door panel not pictured
Any takers?
Its in chandler az
Old 10-01-2018, 03:21 PM   #6
BreckAConner
CB7tuner Member
BreckAConner is cool... so far.
Will you sell the panels, or is that a no? I am trying to find replacement SE Panels for mine.
BreckAConner is offline   Reply With Quote
Old 10-01-2018, 08:35 PM   #7
thepowderblue
CB7tuner Member
I guess it just depends how sweet the pot it, i dont want to. i want to see it back on the road
Old 10-02-2018, 12:22 PM   #8
BreckAConner
CB7tuner Member
Quote:
Okay, if you want to get rid of them let me know. I didn't know that it had a F22b in the car, is that like a F22b2 or 6?
Old 10-02-2018, 01:43 PM   #9
thepowderblue
CB7tuner Member
Quote:
There is no such thing as a F22b6. The usdm F22b engine came in a 130hp b1 or the b2 with a vtec head and it makes a little more power. I wanna say between 140 and 150. They came in the 94 to 97 accords. The only real difference is the head and how some of the accessories bolt up.the heads on the f22b engines have different head porting and 2 mm smaller intake valves and obviously a different intake and exhaust manifold to match up, they did that in an attempt to make more low-end torque but the heads don't flow as well as our F22A's do under high rpms.
With what I have done to it it's surprisingly quick. I am running it With a f22a ecu so i think theF22 a tune makes the F22b2 run a little more aggressive, I have it bolted up to a h23 tranny and no balancer shaft belt.
Old 10-03-2018, 11:25 AM   #10
BreckAConner
CB7tuner Member
I'm curious how the B2 runs now, it must be peppy, but hey you can't forget the 95-98 USDM Ody, it came with a B6.
Old 10-03-2018, 02:53 PM   #11
thepowderblue
CB7tuner Member
Oh Yeah. I forgot about that oddball
The b2 runs! I think most of its in part to the shorter gears of the h23 tranny and not running the balencer shaft belt and power steering. Its just revs and wants to keep going. I take it past the red line all the time. It just keeps pulling
