I got a 92 accord ex coupe 5 speed. My clutch doesn't come all the way back up to resting position. I have to assist it with my foot while i am driving for it to come all the way back up. Which is only a couple of inches but my cruise won't engage like this. I am guessing this is the clutch assist spring causing this. Is this correct. Also sometimes before i start car and depress the clutch it sticks to the bottom. Am again assuming this is related to assist spring. Is this a pretty easy fix if this is the problem?
Clutch pedal doesn't come all the way back up.
Originally posted by zedjr10 View PostI got a 92 accord ex coupe 5 speed. My clutch doesn't come all the way back up to resting position. I have to assist it with my foot while i am driving for it to come all the way back up. Which is only a couple of inches but my cruise won't engage like this. I am guessing this is the clutch assist spring causing this. Is this correct. Also sometimes before i start car and depress the clutch it sticks to the bottom. Am again assuming this is related to assist spring. Is this a pretty easy fix if this is the problem?
ok all replaced, Slave and master. I have a question as my clutch hardly engages with pedal to floor and had to lift up my floor mats for that. So it needs adjusting am assuming. What bolt do i adjust. I am assuming again that it is that lock nut behind the pedal pin and cotter pin. Is this right?
Originally posted by zedjr10 View Postok all replaced, Slave and master. I have a question as my clutch hardly engages with pedal to floor and had to lift up my floor mats for that. So it needs adjusting am assuming. What bolt do i adjust. I am assuming again that it is that lock nut behind the pedal pin and cotter pin. Is this right?
