Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Audio/Electronics
Old 03-20-2009, 03:34 PM   #1
rthles
rthles is cool... so far.
help with head unit
ok all just need help. i just got my first 90 accord with 240,000 on it and the head unit is a jvc that plays well as long as i don't turn the volume over 15 then it turns the unit off the back on and this go's on until i turn it down. so is the unit bad or can it be fixed
rthles is offline   Reply With Quote
Old 03-21-2009, 12:46 PM   #2
DejectedAngel
DejectedAngel is cool... so far.
Well it might be one of these things bro! 1st it might not be hook up the right way. Have you checked the wiring?
DejectedAngel is offline   Reply With Quote
Old 03-21-2009, 06:21 PM   #3
rthles
yes i did checked the wiring and it was kind of funky so i redid it
Old 03-21-2009, 09:51 PM   #4
DejectedAngel
Ok theres a couple of things it might be wrong. Ive had this problem in my 2 cb7s before. Re-wire the yellow wire with the red wire and the red wire with the yellow. Try that if it dosent turn on then re-wire them back to normal. I know it sounds dumb but i have fixed accords and civics like that. 2nd check the stereo fuse on the fuse box. Check it to be the right fuse as well check the stereo fuse in the fuse box under the hood on the passenger side. And if it keeps turning off and on then the last thing is that one of the speakers is not wired right or its making negative contact with something. Hopefully its one of the above bro!
Old 03-22-2009, 01:05 AM   #5
rthles
thanks. i will do that and get back to you
Old 03-22-2009, 10:54 AM   #6
DejectedAngel
Sounds good man let us know.
Old 03-22-2009, 11:27 AM   #7
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
Sounds like what ever source of power your using isn't supplying enough.
wat?
C91BLX7 is offline   Reply With Quote
Old 03-22-2009, 11:13 PM   #8
avaaj
avaaj is cool... so far.
Send a message via MSN to avaaj
Mine does that, I double the electric tape and its fine now.
avaaj is offline   Reply With Quote
audio
