Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Audio/Electronics
Old 10-17-2017, 05:10 AM   #1
Chejay
Chejay is cool... so far.
Can anyone help me with my car audio system?
I have a hobby in electrical engineering so I built my own car audio system given the fact that it didn't have any before. It's basically two pairs of PC speakers adapted with some resistors and regulators to work on DC 11-15V from my car. In order to eliminate any ripple and noise I have added a 4700 uF capacitor in parallel with the power wires. Like this (excuse the paint drawing)
They are low power enough (around 30W max) to work without any noise when the car is running (noise induced by the alternator) as well as when it's on battery only (of course, no noise).
My problem is when the device i'm using is charging from the SAME power lines, all the noise-filtering the capacitor is doing suddenly vanishes.
This is when my problem occurs:
My skills aren't advanced enough to figure out what's going on, so I'm asking here after 1 month of research: How do i eliminate the ripple from when my device is charging and plugged into the audio system at the same time?
Chejay is offline   Reply With Quote
Old 10-17-2017, 08:14 AM   #2
sonikaccord
That is called a ground loop. I believe you can fix it by setting the 3.5mm jack ring terminal or RCA sleeve to the same ground as the speaker/amplifier setup.
audio , automotive
