stock radio issue..yes stock radio..
    So wassup guys... yesterday i was replacing the bulbs on my 91 lx and i couldnt get to 1 particular bulb for the low beam by the battery. AFTER 30 min of strugglin cuz my hand barely fit in the tight spot i removed the battery... replaced bulb and put back the battery... so i go for a drive once im done and NOW THE RADIO DONT WORK. well it does power the antenna and the illumination lights do come on but no sound or display... remember i have a stock HONDA radio...
    Do you have the radio code? It may be locked out.
    At worst, it could have just died.
    YouTube Clicky!!
      I also want to say check your radio fuse in the fuse box too.
      Follow me on IG: @jdm_inspired
      93 'til infinity
        I checked that just to make sure but unfortunately i gotta take that radio out and get the serial # so Honda can help me unlock... dont wanna change the radio... smh
          Honda has a site they made for you too get your code right away as long as you have the info needed. https://radio-navicode.honda.com/
          you need the vin# and the device serial #.
          Sold too: Grumpys93, '93CB7Ex, Bunta, prodh22accord, SSMAccord, fleetw00d
            NICE ima definitely check that out... now i gotta take that damn radio out to get the serial #... smh
              In with the owners manual and other paperwork should be a credit card sized card with the 6-digit code on it. I usually write the code on the radio in case the card gets lost, because if someone steals the stock radio, they can have it lol
              1992 Accord Wagon (RETIRED)
                I didn't realise adding SMH to the end of every paragraph made cars work better, thanks for that tip I'll keep that in mind
                sold! But here's my build thread for those interested.
                http://www.cb7tuner.com/vbb/showthread.php?t=206864
                  LOL didnt even realize that
                    So someone referr3d me to the honda codes page and i input my VIN and Serial and now shyt tell me that is not the proper serial for thw original radio..... FML do know what to do i wanna keep the car original and now that blows
                      I had the same problem when i bought my car. The stock radio would come on some times and sometimes it would be completely off but the antenna worked. So i headed down to the junkyard and got another radio and it worked perfect and had the stock eq on it😍. You could also get youre meter out and make sure its getting power
