Old 06-19-2008, 02:02 PM   #1
MadSpleen85
MadSpleen85 is cool... so far.
Send a message via Yahoo to MadSpleen85
What's the Difference? Auto vs 5spd TB's?
Searched but couldn't seem to find anything that answered my question..
What is the difference between the Automatic and 5spd Throttle body's on the H23?
I have 2 H23 TB's but they both look different, one was off a swapped CD accord in the junkyard, and the tranny was already gone when I found it, the second was purchased locally and the guy that I bought it from was not sure which it was off of.
Here are a couple pics of the two side by side. I can get more if needed.
MadSpleen85 is offline   Reply With Quote
Old 06-19-2008, 02:13 PM   #2
benjerman112
benjerman112 is cool... so far.
To me looks like they are from different yrs cause when i did my h22a4 swap it had the map sencer on top but i needed the one w/out and had that lil tube off to the side. one looks to have a smaller opening, the one on the left looks like the one i got off a older h22, and it one has that xtra stuff on the throttle rotor but i know you saw that.
Freedom Is Not Free
U.S Army 02/08 Medically Discharged
benjerman112 is offline   Reply With Quote
Old 06-19-2008, 02:26 PM   #3
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
the manual one has a single throttle rotor, while the auto one has TWO throttle, one for the tranny kickdown cable.
i only wonder if the diameter of the TBs are different, but thats hard to tell from pics - very easy to judge by just putting them up against each other.
either one will bolt on and work the same though - so use the bigger one
Old 06-19-2008, 03:16 PM   #4
HondaFan81
Honda Enthusiast
HondaFan81 seems to have made some friends! HondaFan81 seems to have made some friends!
2nd post down in thread link below, has photos & explanation.
http://www.cb7tuner.com/vbb/showthread.php?t=38936
HondaFan81 is offline   Reply With Quote
Old 06-19-2008, 05:21 PM   #5
bruno8747
bruno8747 is cool... so far.
Send a message via AIM to bruno8747
The h23 one is also bigger than the 5th gen accord tb. Auto JDM h22 throttle bodies are the same size as the D series civic throttle bodies. I've measured them and they are the same size and same bolt pattern.
bruno8747 is offline   Reply With Quote
Old 06-19-2008, 05:22 PM   #6
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
Kickdown cable
wat?
C91BLX7 is offline   Reply With Quote
Old 06-19-2008, 05:31 PM   #7
Law Grandeur
Law Grandeur seems to have made some friends! Law Grandeur seems to have made some friends!
Send a message via AIM to Law Grandeur
dude seriously? makes me wanna replace my auto tb
no
Accord turbo kit under $2k here
$30 HID kits here Thread
"What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
"No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
Law Grandeur is offline   Reply With Quote
Old 06-19-2008, 05:42 PM   #8
PR CB7
PR CB7 is cool... so far.
Send a message via MSN to PR CB7
the one with the map sensor dont look like a h23 TB at all
the coolant nipple that is integrated in the TB is facig backwards
unlike the H22 and h23 the fast idle is smaller
the actual opening looks smaller
apart from the rotor the SHOULD all be the same
i just swapped one yesterday
Just do what PR CB7 said.
PR CB7 is offline   Reply With Quote
Old 06-19-2008, 07:40 PM   #9
R34Accord
R34Accord is cool... so far.
Send a message via MSN to R34Accord
ive not connected the wire to the second pulley on TB.. Have an automatic..
Just swapped it.. Wouldnt the tranny shift?
Accord M0DiFi3D From Norway
Visit Website: http://www.garaget.org/?car=63883
R34Accord is offline   Reply With Quote
Old 06-21-2008, 02:55 PM   #10
bmxfelon420
bmxfelon420 is cool... so far.
It probably wouldnt kick down a gear properly when you floor it while in a higher gear. I'm not 100% sure on that, not going to unhook mine to go test it out :O
Cars:
91 Accord LX Sedan (sold)
98 Accord LX Sedan
95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
bmxfelon420 is offline   Reply With Quote
differences , h23 , throttle body
