This is on my civic by the way.
I went through DEQ today and failed because this came up...heres what I got off google.
"Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
A code P0135 may mean that one or more of the following has happened:
* O2 Heater element resistance is high
* Internal short or open in the heater element
* O2 heater circuit wiring high resistance
* open or short to ground in the wiring harness
Possible Solutions
* Repair short or open or high resistance in wiring harness or harness connectors
* Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)"
Any ideas what I should check out...apparently my check engine light should be on which it isn't even lit up. I need to fix this asap.
Possible Solutions
