ok you guys i just got this coupe from Jarrett and i cant get it to start. the car has been sitting for 13 months. so i dropped the tank and emptyed the fuel checked to see if the pump was still good while it was out and it was. so the i checked for spark i have it. but here is the problem the injectors wont spit and the fuel pump wont prime. but when you turn the key to start it the pump works. im so lost right now i checked all the possible fuses and the main relay. what else could it possibly be
car wont start
Change the fuel filter. It could be clogged (if that's upstream from where you already know you're getting fuel)
Or you have badly clogged injectors to me. Which is possible if it has been sitting 13 months.
Try cleaning the injectors too.
Or, first, make sure your spark plug wire order is correct on the dist. cap.
You've verified spark at all four plugs, but if the timing sequence is off then the car won't start or run.Last edited by batever; 06-15-2009, 02:23 PM.
