im debating on a KnN filter or air intake.... which of the two should i go with... friends telling me air intake.. is there any difference in the two if so what.....??
knN Filter or short ram intake
MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
Originally posted by quaidumyou being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
good job, just what the world needs more inconsiderate driversTags: None
Originally posted by CB7 R3ason View Postim debating on a KnN filter or air intake.... which of the two should i go with... friends telling me air intake.. is there any difference in the two if so what.....??
So, in summary:
KnN drop-in: $50, only change the filter in the box, stock piping kept.
Short Ram: between $80-$175 changes the intake piping, but filter still inside engine bay.
Cold-Air: between $200-$275 Changes intake piping, and reroutes filter to out of the engine bay allowing colder air to be taken in.
I know it's long, but i hope this helps in your decision!
Please learn to type!!
CHECK IT! My ride thread...
http://www.myspace.com/stephenwaltonphotography
Originally posted by deevergoteYou'll need to spend real money on parts with real engineering to see any real gains. Anyone who says otherwise is either ignorant, or trying to sell you something.
Originally posted by Tippey764 View PostGet a drop in filter
The only difference with getting a short ram is the sound.
Originally posted by kellogg_racing_ View PostI was worried I had made a mistake just getting the drop in: you really think its just as much as an improvement with the drop-in as the whole short ram?
Honestly you wont notice a difference with either setup.
I did an h23a1 intake manifold swap and am still running the same stock intake box. i definetly notice a huge difference in my cars preformance after the swap even with the same intake box.
Originally posted by Tippey764 View PostI did an h23a1 intake manifold swap and am still running the same stock intake box. i definetly notice a huge difference in my cars preformance after the swap even with the same intake box.
Thanks for the help too!
Originally posted by kellogg_racing_ View PostThat's what I've been wanting to do. Once you find one (from junkyard, whatever) how much of a hassle is it to hook that bad boy up? I keep hearing you gotta hook up the vacuum line from some kind of secondary butterflies to a black box? What else do you have to do to make it work? I hear its an exact bolt-on fit though.
It depends on what engine you have honestly
If you have an f22a6 its alot easier becuse the intake manifolds are so similar.
if you have an f22a1 you need to hook up the butterflys to vaccum line or install the black box and you need to adapt the coolant lines to run to the new fast idle valve and IACV
over all its an easy swap and creates a big gain on f22a1 engines because they're current intake manifold is so restrictive in compairson to the h23a1.
Originally posted by casterX View Postadditional info you might want to consider..
http://www.cb7tuner.com/vbb/showthread.php?t=56646
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Originally posted by kellogg_racing_ View PostOh shoot. Sorry. I've got a f22a4.
f22a1 and f22a4 both have the same intake manifold ( the restrictive one )
The h23a1 intake manifold upgrade is good for both a1's and a4's
Also you might want to look into getting a p12 ecu from a 1992-1995 prelude S
Originally posted by Tippey764 View PostAlso you might want to look into getting a p12 ecu from a 1992-1995 prelude S
