Steering
    Steering
    is there a better steering rack for the 1990 accord?
    i don't care for the turn radios, i would really like more of a race car feel.
    What's a turn radio and what's a race car feel like?
    '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
      you can try to see if an Acura Vigor one would work. It was based off the CB7 chassis (rear sway bars, brakes are a direct swap), chances are the steering might be compatible.
      member's ride thread
      91 Accord SE 176k
        I believe he means ratio.
        There's a lot of other options out there that will be alot easier to go race car than the cb accord. They're built for daily.
        Not saying don't just saying you have other much better options
        sold! But here's my build thread for those interested.
          thank you, IL see if there is any acura in the salvage yard close to me.
          do you know if an integra rack would work?
          by race car feel i mean when i turn the wheel it responds quickly, and takes less turning of the wheel for sharp turns.
          i meant steering ratios
            You know most race cars have lower sensitivity racks. It improves high speed stability. What you want is quick response, not high gain. Getting quick response has nothing to do with the rack. It's tires, shocks, bushings, and a little spring. Steering ratio only affects how much you have to turn the wheel. But because of dynamic steering ratio from kinematics and compliance you can change your effective steering ratio while turning (and driving) just by changing your tires.
              thank you
