so i was reading elsewhere that the F22aX crankshafts were the same as the H23aX cranks.. both have 95mm stroke & 50mm main journals..
just need to confirm this. thanks.
what year h23 crank did you look at.. the 97-01 h23's i think are supposed to have 55mm main journals.. .. i'll look up part number now that you mentioned it LOL
Looks like the 92 and 93 Si models used the 13310-PT3-315 crank, 94-96 used the 13310-P0A-000 crank. I believe the only real difference is the crank bolt. The PT3 crank uses a 14mm bolt, the P0A uses a 16mm bolt.
