valve adjustment
    Originally posted by Bad_dude View Post
    I don't recall but does the mark "UP" also on the side of the cam pulley or do I have to take the top timing cover off?
    Thanks.
    Mine was on the pulley
      If yours is an OEM Honda that's fairly new you should be okay. You won't know for certain until you've tried to put it back on though.
        just to verify, when i rotate the engine and watch for the cam gear to go 90 degrees, i'm unsure which way the gear should be going. I know the Hayne's manual says rotate the crankshaft pulley counter clockwise, but i will be turning the PS gear instead. So i'm not sure which way that would in turn make the cam gear move.
        IE i have my timing cover on so can only see the side of the cam gear facing the cylinders
        therefor do i move the UP marking 90 degrees towards the front or rear of the car to get to cylinder #2?
        -- Check out my CB -- My CRV blackhousing thread!!-- My CG coupe--
          Towards the front.
            much appreciated.
              much appreciated.
              Are you going to do yours? Take some pics would you.
                yessir
                i have my rocker arm assembly off right now to do the lower tube seals
                tomorrow i will take some pictures, but as a first timer for valve adjustment im a teensy bit weary.
                im following the cb7 community instructions (always a good idea) and ericthecarguy on youtube. his videos are amazing, as already stated.
                but ill throw up a few pictures when all is said and done
                  yessir
                  I don't have to do my lower seals yet, but could you get those pics as well? Let us know how that goes.
                    yup.. taking of the rocker arm assembly seems daunting if its your first time, but it wasn't bad
                    just remember to turn in small increments, using the proper tightening/loosening sequence (generally from the outsides of engine to the inside. can be found in a Hayne's manual and on the site somewhere)
                    there's a diy for the tube seals right hurr:
                    http://www.cb7tuner.com/vbb/showthre...diy+tube+seals
                    and also, ericthecarguy does a great video for this on youtube.
                    some manuals, and members of the site, suggest placing cylinder one at TDC before taking off the assembly, which is what i did. But the youtube video doesn't suggest that.
                    I noticed everyone else's assembly was a lighter color and looked healthy. mine obviously burnt oil..it was very black and burnt on there.
                      I have done this to my car and from experience my advise is as follows:
                      I used and recommend a "feeler guage" that is bent on an angle (not the straight one that is usually used on spark plugs). This will give you a more accurate "feel" which can make a big difference. A drag feel due to incorrect angle can lead to incorrect adjustment.
                      Be methodical and take your time.
                      Check, re-check and re-check again (even if you feel sure). You dont want to re-do it again when an extra 5 mins observing etc may discover a human error (eg. forgetting a tool or its tight but the assembly is actually not sitting flush).
                      Use only Genuine Honda seals. You saved on the labour, dont cheap out too much or else you will pay by additional unecessary labour (doing this is not too hard but re-doing it again prematurely or unecessarily will p*ss you off).
                      Also after the adjustment it may still sound a tad noisy. Give it a few months to settle. Mine did and it purrs now.
                      Remember: Better to be a tad loose "noisy" than a burnt valve!!
                      Rides:
                      Accord
                      CR-X
                      88-JDM-Si- Black
                      CR-X Del Sol
                      92-JDM-SiR "Transtop" - Black
                      Prelude
                        And doing this to Honda specs as stated above, you'll still want to do this with the engine cold, correct?
                          Yes, Honda spec is <100 degrees F, buy I try and do it in the morning when it's the coldest.
                            i've been reading that its possible to through off your timing "on accident" while the rocker arms are off.. what would exactly throw off the timing?
                            just don't wanna have any (additional) issues here.
                              The only way your timing could possibly get thrown off when the rocker arm is removed is if the camshaft lifts up from the tension of the timing belt and the belt slips off the cam gear. I have removed many rocker assemblies and NONE of them have even barely lifted up from the tension, just watch it. As long as the cam stays in the head and the belt doesn't slip off, the timing will stay put.
                                good deal.. i'm honestly not all too savvy with internal engine components, but that's one thing i was trying to watch for.
                                thanks
