The STILL don't know what I'm doing 5spd/jdm swap build thread!
    Continuation of this thread http://www.cb7tuner.com/vbb/showthread.php?t=205734 because i posted in the wrong section. Only update is that my swap mounts are in and I went to the yard and pulled a clutch pedal. On that note, does anyone know how to get the brake pedal arm off? I could not for the life of me figure it out, it was a little cold and obviously cramped in there but a little insight for the next visit would be helpful.
    dem mounts tho
    removing/install the pedals looks to be a miserable task...theres just no room to work with, I dont see how this is such a popular swap lol. Maybe once I actually do it I'll look back and say its easy
    The easiest way is to just pull the pivot bolt for the brake pedal and pull the pin for the master cylinder. Once you do that the whole pedal itself should just drop out. It's much much easier than swapping out the assembly. I'm a big guy and it wasn't the best thing in the world but it's accomplished within 2 hours.
    I did the swap myself a few weeks ago and I accomplished it all within a day. It's worth it in my opinion, especially since everything just bolts in.
      Thanks Mike, hopefully I can pick that up on my next run
        Unbolt the driver's seat and you will have plenty of room.
          x2 You'll have more leg room than a Bently. Make sure you get the two safety switches that the pedal presses to start the car. There should be two rubber stopper bushing things on the pedal too, don't forget those.
            The switches are only necessary if you plan on keeping cruise control and wiring the other switch as your starter safety switch.
              Not dead, just been busy! Started new job working at a honda dealer and that consumes all of my time. I did, however manage to pick up a m2f4 trans, I have a h23 trans also and got a bunch of parts needed for the manual swap
              now I think I need to order this for the wiring, a ecu with a decent basemap for the motor I put in
              http://www.rywire.com/product-p/sub-...subharness.htm
              and this to solve the whole clutch dampener situation
              http://www.rywire.com/rywire-accord-...-line-h12m.htm
              And of course the motor...although I'm not pressed to get it because I dont really have anywhere to store it. Plans are to still go with the h23vtec unless I come across a dumb deal on a h22
              also..here's a picture of my daily...just because lol
                Here's the trans, hopefully it works!
                Was nice out today, decided to put the pedals in. Holy hell boys you guys werent kidding about the spring thing being a bitch to install lol
                  man that truck is CLEAN.
                  COUPE K24
                    lookin pretty good good!
                      Thanks guys! I wanna say I'll end up having a motor by the end of the month but something always ends up happening.
                        Nice truck man
                          Thanks boss
                          Hopefully picking up an h22a tomorrow for this thing. Anything I should do while the motor is out? I dont care about having a clean engine bay or any of that crap, just stuff that will make the swap easier. I still need to buy a clutch line, the jumper harness and a ecu
                            Got a little present for my cb7
                              what dis that run you and where did you get it from
