Question about Sway Bar End Links
    AM replacing my sway bar end links and am not sure which way the washers should face. There is a flat side and one slightly rounded. Should the rounded side be touching the bushing or should it be against the metal(bolt or spacer).
      Ok cool. I see on yours that curvy end goes on metal. My oem ones are flat on both sides so i couldn't tell. Thanks.
