Is a F20a a decent engine?
    Alright i want to get a accord with a f20a swap in it. does anyone know the specs on it? hp, torque, compression ect. will i be able to find parts for it? internals, basic engine tune-up parts, belts, pulleys ect.
    its more than decent to me.
    and which one is it, sohc or dohc?
    Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
    -(B-Pillar Bar Originator)-
      doesnt say but im pretty sure its sohc. but i could be wrong.
        i had an f20a sohc nothing great about it. never seen a f20a dohc
        Bore × Stroke: 85.0 × 88.0 mm
        Displacement: 1997 cc
        Compression ratio : 9.5:1
        Valve Configuration: SOHC, 16 valves
        Max output : F20A2 / F20A4 / F20A8 110 PS @ 6000 rpm (PGM-carb) 133 PS @ 5400 rpm (PGM-Fi),
        Max output : F20A5 135 Ps @ 5400 rpm (PGM-Fi)
        Max output : F20A7 147 PS @ 5600 rpm (PGM-Fi)
        Max torque : F20A2 / F20A4 / F20A8 18.5 kg m @ 4300 rpm (PGM-Fi), 16.1 kg m @ 3800 rpm (PGM-carb)
        Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-Fi)
        f20a dohc
        Valve Configuration: DOHC, 16 valves
        Compression ratio: 9.5:1
        Max power: 150 hp (112 kW) @ 6100 rpm
        Max torque: 137 ft·lbf (186 Nm) @ 5000 rpm
        Freedom Is Not Free
        U.S Army 02/08 Medically Discharged
          alright thanks. any other imput would be appreciated
            hah, why is boobs a tag for this thread?
              maybe perverts searching threads could give some imput haha
                Either one is pretty good. The SOHC is basically an F22A with less displacement.
                  alright thanks
                    y'all forgot F20A1, which i have in my cb (due to the engine had to be overhauled, was the only thing available at the time). You may also want this link, it's well worth lookin over cause it has all honda motor codes. Your most welcome
                    http://www.hondagranturismo.it/artic...ici_motore.pdf
                    F20A1
                    Compression ratio: 8.9:1
                    Fuel delivery: PGM-Carb
                    Max power: 90 hp (66 kW) @ 5500 rpm
                    Max torque: 110 ft·lbf (149 Nm) @ 2700 rpm
                    Redline: 6000 rpm
                    From hands on experience i would say good low down torque. It will pull its weight to give you those 90 horses trust me. i got up to 110 mph (180kph) in it but it takes a lil while.
                    Even though i should not be really condoning this but just to give you an idea of what it can do, say your up against "all these stock of course" a '93 civic d15b non-vtec, '94 GS zuki swift and a '96 hyundai accent. And those car are putting out almost about the same amount of power just for FYI. But yea hehehe, just watch the headlights of those cars get smaller in your rearview mirror.
                    But like what benjerman112 said there's nothing all that great about it. It gets you where you want to go in good time
                    '91 Concord Metallic Blue. Status: under construction
