Legend Caliper Swap
    Legend Caliper Swap
    I'm planning on swapping Legend Calipers up front that I got from Tippey. I will be using 91-93 wagon rotors, and as of right now I have a 28T brackets which I might swap out for some 25T brackets, if I can find some, when I do go through with the swap.
    Is it recommended that I get pads that are for the CALIPER? So buy legend front pads? or is buying 91-93 wagon pads alright?
    are the wagon rotors 25mm?
    Where can I pull 25T brackets from? do the 91-93 accord wagons have them? and if so, which part is the bracket, and how can I tell which type of bracket it is? is there number on the part that I can see?
    thanks in advance to anyone that can provide some insight for this, I really appreciate it!
    Let's see........ the pads you use should be bought for the calipers, so yes, you should use Legend pads. The wagon rotors are indeed 25mm thick and should be used with the 25t bracket for proper caliper alignment with the rotor. The bracket is the piece surrounding the caliper held on by 2 14mm bolts. The number of the bracket is stamped into the metal. The 25t bracket can be found on 91 to 97 wagons...... I think that takes care of all the questions.
      Thank you so much! you really came through for me, coupes! I'm about to hit the yard today, so I really appreciate the fast response
