New Oil Pump Installation
    Hey guys, I have been in the process of freshening up the F22A4 that I pulled
    out of my car.
    I had a question about the oil pump. When I pulled the old pump off & while I
    have been cleaning the mating surface on the block it looks like from factory
    some RTV or sealant was used around some of the edges.
    When I install the new pump should I be using some RTV or sealant?
    If so are there specific spots or corner parts I should use it on?
    Keep Pushing..
    Nevermind, I flipped the page on the haynes manual & it says apply a thin coat of RTV sealant to the pump housing-to-block sealing surface.
    Keep Pushing..
      Make sure you get those corners!
      YouTube Clicky!!
        Thanks! Will do!
        Keep Pushing..
          Make sure you use Hondabond HT. Permatex grey is ok, but shouldnt be used where its impossible to get back at.
