oil light come on
    One of those two wires goes to Instrument cluster and the other goes to Integrated control unit as per Haynes manual.
    I looked for this integrated control unit on the diagram but cannot find it so far.
    I am not sure if this ICU is the same thing as ECU since the diagram shows ECU as "PGM-FI Electronic Control Unit".
    A&P-IA
      Originally posted by oaxaco1985 View Post
      I'm using a mixture of 3 nextgen oil and one royal purple for this oil change as I want to swap it to full royal purpel
      What weight oil?
      It seems like the light is on for the right reason, minimum oil pressure at idle at operating temp is 10psi, if it is less you are to check the oil pump. This is from the service manual. Also minimum 50psi at 3000rpm.
        well the light only comes on when the car is running at a load of 75 psi at 65 mph, I looked at it today and chase the two wires and I found that it doen't go to the computer at all so I wire both cable to a differrent, one to the actual pressure swith and the other to the oil pressure gauge sensor to see what it does and the light didn't came on at all
        I'm using 5-30 motor oil 4 quarts of it for the moment I have 3 regualar oil and one of royal purple as I want to clean the inside before I change to fully royal purple
        [IMG][/IMG]
          [IMG][/IMG]
          Good work! oil light is serious issue!
