My 93 coupe dosnt have any on the rear,Imo I love them I had them on my sedan I think it gives the car a wider look. Im actually thinking of getting some rally armor ones to put on the back idk but I think it'll look kinda sick if I mount them right. For some reason I've always seen the accords with an awd look, I dont know why probably because I've wanted to make one that way since I've owned them.
Delete mudflaps?
take them off....you'll get 1-2mpg better at high speeds.
member's ride thread
91 Accord SE 176k
Originally posted by Losiracer2 View Posttake them off....you'll get 1-2mpg better at high speeds.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
from what I understand, the 9091 flaps say honda on the rear, 9293 don't. Don't kno which models**Blk Housed Slut Crew Member #1**
Originally posted by Accord problems View Postand how do you come to this conclusion ?
Drove the same route M-F, to and from work, at the same time of day, setting the cruise to the same exact speed, filling up at the same costco gas station.
Its all aerodynamics. Air gets trapped in the mudflaps at higher speeds since they stick out from the body of the car a little bit. Remove them and your car has a lower drag coefficient.
91 Accord SE 176k
but not every cb7 is the same . they look the same but some have more flair ect... . then some have wider tire's so what work's on one cb7 may not work on another . that's why i asked you . thank's for the reply .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
When it comes to mudflaps, it is a personal preference for street cars. The OEM replacements are not hard to find on Ebay. Both front and rears come right up in a search. They really do make a difference on the street as far as their intended function. If, however, you have a non-street legal project, like a drag car, then I would take them off and put painter's tape on the bottom of the front quarter panels and front doors near the tire if running slicks. Then you can just peel off any residue that shows up with the tape.*** Think of others before thinking of yourself. ***
MRT
Selling on Ebay!
15.10 @ 90.42mph
Current fastest Laguna Seca Lap: 1:52.889
I picked up a set from the JY when I was in New Zealand, put them on my car and they dont quite fit properly I have a feeling I took them off of a 9091 and im fitting them to my 9293, I mean they do fit but theres a gap between the bumper and the actual mudflap where its supposed to meet.
I cant be arsed tracking down another set, and Ive already got them installed so no point taking them off again.]
Just a note (Im sure heaps of people already know) but yeah, 9091 and 9293 rear mudflaps may not be 100% swappable due to slight differences between the shapes of the rear bumper..
