Old 08-22-2018, 08:34 PM   #1
BayArea_CB7
BayArea_CB7 is cool... so far.
Replace tps
Trying to remove my old tps to install a new one and came across an issue, the stock tps is semi permanent. How or has anybody removed it and still be able to use the stock throttle body.
BayArea_CB7 is offline   Reply With Quote
Old 08-22-2018, 10:20 PM   #2
F22Chris
What are you having trouble with exactly? The TPS is two fasteners and a paper gasket to R&R.
Old 08-23-2018, 07:18 AM   #3
sonikaccord
Cut a slot in the bolt and use a flathead screwdriver. It's not a rivet it's threaded.
YouTube Clicky!!
