Old 06-28-2012, 06:21 PM   #41
Bad_dude
Bad_dude seems to have made some friends! Bad_dude seems to have made some friends!
Cool Just readjusted my valves today.
I readjusted to be a little looser. The throttle was not as responsive, but I hope it might save some gas.
Previously I had it with the intakes at 0.009 in. and the exhausts at 0.011 in.
I readjusted to instakes 0.010 in. and the exhaust 0.012 in.
Here's a video after the adjustments. Are the valves still ticking too loud? The video is made after the car has been driven and fully warmed up.
Thanks.
Bad_dude is offline   Reply With Quote
Old 06-29-2012, 08:35 PM   #42
Bad_dude
Cool
Well, no input as to my motor is ticking too loud or not? Post your motor sound video so I can compare.
Thanks.
Old 06-29-2012, 11:11 PM   #43
10thAnnivCB7
10thAnnivCB7 is cool... so far.
Mine ticks a bit but its so quiet at idle ,, ill try and record it tomorrow when it's warmed up and upload it
10thAnnivCB7 is offline   Reply With Quote
Old 06-29-2012, 11:17 PM   #44
Bad_dude
Question
I don't think I have ever heard this motor without ticking, even after an oil change. Here's a prelude F22a1 motor.
F22A1 sound.
Old 06-29-2012, 11:23 PM   #45
10thAnnivCB7
dude i don't know why this iphone will not let me see videos uploaded here but it used to work ,, androids all day ,, send me the URL
Old 06-29-2012, 11:26 PM   #46
Bad_dude
Cool
Dude,
Not just you. Even I can't see my own post video. But I make it into a link. I thought because I got rid of Java. But it's not that.
Old 06-29-2012, 11:33 PM   #47
10thAnnivCB7
idk ,, also restrictions of any kind can be diagnosed as ticking or tapping ,, i cleaned my IACV and FITV and re adjusted the base idle and that made it a bit more quiet and starting RPMs are around 1500 which i've read is good ,, warms up in 3-5 mins depending on weather
Old 06-30-2012, 12:57 PM   #48
Bad_dude
Cool
Our F22 is always going to have ticking. I just want to compare to others to see if I should tighten them up a little or not.
Thanks.
Old 06-30-2012, 01:02 PM   #49
10thAnnivCB7
Here's the video man ,, i was holding it in D4 just to see if it was loud but its actually more silent when i hold it in gear than when i put it in park.
http://m.youtube.com/watch?v=wv_vRmkySKM
Old 06-30-2012, 05:29 PM   #50
Bad_dude
Question
It ticks about as mine. How many miles you got on the motor?
Old 06-30-2012, 07:55 PM   #51
10thAnnivCB7
a bit more than 165xxx ,, i got it last summer with 144xxx so since August 1st ive put over 20,000 miles only on weekdays. I dont drive it on weekends unless i have to.
Old 06-30-2012, 07:59 PM   #52
Bad_dude
Question
Dude, that is a lot of miles on the car. I barely put 1100 miles since June of last year. No job, no drive any where. Lol.
Old 06-30-2012, 08:17 PM   #53
10thAnnivCB7
my brother gives me 20 for gas and the guy i carpool with gives me 25 and that's 30 for gas and the rest for me to buy things for the car if it needs it
Old 07-19-2012, 12:20 PM   #54
Bad_dude
Cool
It seems like my gas mileage is improving. When I had my last tank less than a half, I managed from 20 to 22 MPG. Now on a new full tank, the meter seems to stay put toward full longer. We'll see when this tank is gone. It'll be a while as I don't work and it takes longer to empty it. Most of the driving is in the city too.
Old 04-14-2014, 08:53 PM   #55
DCB7
DCB7 is cool... so far.
Thanks for the write up
I did this today using this and the ericthecarguy video
I also noticed the pictures were not working, so I took a few while I was doing it (maybe they can replace some with broken links):
when I removed the wires and plugs
removed distributor cap (removed air filter to access lower screw)
then removed valve cover
I used wrench a to turn motor counterclockwise
when the arrow on the sprocket was nearing straight up
I slowed down and lined up the notches on the gear with the cylinder head
and made sure the distributor rotor was pointing at wire one (couldn't find marks on flywheel)
I used the feeler gauges to check the gaps according to spec
I didn't adjust most of them because they felt just right to me. 2 intake valves were too loose, and a few exhaust ones were too tight, so I backed them off. Hardest part for me was breaking the screw loose from the nut, I got a better screwdriver and got it done.
oh, you should make sure the torque wrench handle is tight, and don't over tighten the valve cover bolts
DCB7 is offline   Reply With Quote
accord , gauge , honda , seals , valves
