what does this go to!?
    Starting a mild tuck on my cb, mostly just headlight wiring on each side, question is what the hell is this and what does it go too. would be very easy to delete if its not important. Part is circled in second picture to the right of the bay.
    Ill also include 3 shots of when i purchased the car, how it looked last year, and how it looks now so you can get an idea of progress.
    day i got it
    last year ( see circled part on drivers side)
    engine bay as of right now
    It's the resistor box for the injectors
      You need that. When I tucked my autmatic cb, I put it where the cmc bolts to. Idk if you can do that with a manual, but you can always put it behind the fender.
      wat?
        Thanks guys you know if there is enough harness on the drivers side to run it through the fenders without lengthening the harness?
          From what I've read, you won't have to extend any of those wires, just deloom the harness and it should free up enough slack to do what you need... I haven't done this, just going from memory on what I've read.
            High beam needs to be extended.
            COUPE K24
