Car Accelerates Really High On Its Own!
    i turn my car on and it accelerates over 7,000 rpm and stays like that i need help i really need my car for work!
    better start inspecting the throttle cable and also remove the intake to see if something is physically holding the accelerator open. later.
    Avoiding dirt at all costs
      ^^Agreed.
      Or a massive airleak - is the throttle body/intake manifold secure?
      My 5.7 LS1 Holden Ute
        is it a toyota?
          Originally posted by scudweiser View Post
          is it a toyota?
          I understand what you are trying to get at, but honestly it wouldn't matter if it was a lawnmower, the principle is the same for this particular question.
          OP Can you give more details on the vehicle / engine?
            its a 92 honda accord automatic
              kinda sounds like throttle cable. I had a 92 wagon and one day out the blue the gas got stuck...look at the cable, if its very rusty and rubber protector is all chuwed up chances are thats the cause
              Originally posted by Uncle Willey
              When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
                same thind happened to me in my old maxima. was driving down the interstate 4 hours from home, no clue about anything mechanical(was like 10 years ago) and all the sudden my car started red lining. after scratching my head looking at the engine for 10 minutes i was like wtf is that acorn doing there. i dont think an acorn is part of the motor. so it had gotten stuck in the throttle cable and i removed it and it was golden.
                so my guess would be throttle cable first, then maybe gas pedal stuck? idk random thought but stranger things have happened.
                Parts For Sale
                BIG Thanks to HondaFan81 for all your help!!
                  Originally posted by evil_demon_01 View Post
                  ^^Agreed.
                  how does an airleak in the throttle body/intake manifold increase the rpms?
                    The same way opening the throttle plate does.
                      Although less likely check the spring on the throttle key(on the TB). A friend of mine's broke and it had the same symptoms.
                      Call me Travis.
                      2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
                      1992 Accord LX ~ "Smoothie"
                      1991 CRX Si ~ Hellion
                      1989 GMC S15 ~ Oldie
