91 accord not starting
    I just took everything off the block to change the headgasket and I put everything back and connect everything but seems like its either not timed and no gettin gas cause I took the fuel line that goes to the injectors and no fuel I'm just out idea and I set the cam and cam gear in the up position but all I get is it turning over that's it and when it turns over it makes a noise like something is off idk help
    I can't understand a single thing you are saying. Slow down, and type clearly.
    Check your valve timing.
    Check to see if you have spark and fuel.
    No spark, check all battery connections, grounds, distributor and attached components, plug wires, and plugs.
    No fuel, check the main relay, fuel pump, injector resistor box, fuel filter, lines, and injectors.
      Originally posted by johnny12 View Post
      ...and no gettin gas cause I took the fuel line that goes to the injectors and no fuel
      Your fuel rail isn't priming. You may have missed a small connection in the fuel wiring. Either that, or, one of the fuses or relays went out while you were taking everything apart (for whatever reason).
      I <3 My Honda CB9!
      My Hondas
      1992 Integra LS Coupe (Sad story...)
      1995 Civic VP Coupe (Traded for->)
      2002 Civic EX Coupe (Traded for->)
      2006 Acura MDX (Long story...)
      1988 Accord DX Sedan (Donated to a friend)
      1992 Accord LX Wagon (Sad Story)
        Well I have spark just no fuel and I didnt set tdc on the pistion or the crank on the bottom either but I'm I set everything to tdc and find out why no fuel then I should be good to go
