ECU manual to auto question
    I have an a6 manual that is going into an a1 auto, but I have to keep the auto trans. I understand I need to use the a6 ecu in order to operate the secondary intake and the proper fuel map, but what do I do about the trans part for the ecu?
    Also, which engine harness do I use? I intended to use the a1 due to its additional trans sensors but noticed there's a sensor under the a6's intake on a vaccum box that the a1 doesn't have. What wiring do I need to finish this conversion?
    You’ll need an auto PT6 ECU (A6 ECU).
    As for the wiring, you can simply add the necessary wires for the IAB system. Everything else should work from your A1 setup.
      Thank you Deev. Is that added all the way back to the ECU or would the connector at the firewall going into the footwell have the correct wiring?
        I THINK it’s back to the ECU. Check the pinout and how your A1 plug is wired.
        I had a shop swap out my A1 for an H22 before I knew very much. Learned years later that my IAB setup was done wrong, but I never got around to fixing it.
          I put an A6 in my 90 LX. I had the bypass valve on the intake upstream of the air filter. I swapped the wire for the solenoid for this valve at the ECU into the position to operate the IAB solenoid. I got the wires for the IAB solenoid from an A6 harness from a JY and swapped them into the harness in the engine bay.
            I intend to yank the plug for the iab from the donor engine, I'm headed to the JY now to grab the ECU and maybe the whole engine harness and then I only need to run the line from the firewall to ECU for iab.
            The car I'm installing this in is a 10th anniversary, it has rear disc brakes, was that common? I thought I read that it was a dx with a couple "extras"
            I ask because, it seems more like an ex but doesn't have a moon roof... and a busted a1 engine.
              It’s basically an LX with “extras”. Rear disc brakes were one of those extras.
              It’s somewhere between LX and EX, basically. It has the LX/DX engine and roof. EX alloys and brakes. And painted moldings, which are unique to the 10AE (and maybe S.E... memory fails me.)
                SE models also had painted moldings.
                Based on Majestic's site, the 93 10AE did not have the bypass valve upstream of the air filter, so it may have the wires for that in the harness from the ECU to the engine bay.
                  confirmed last night that the pink/blue wire that grounds to the ECU for the IAB is not in the firewall harness. The 12+V wire location in the EX model harness is occupied with some other wire in the 10AE.
                  However, the plug on the 10AE does have 2 open pin spots, the pink/blue location is available and the top right corner when looking at the engine harness plug.
                  I'll be using both to wire the IAB up. I'll have to find a 12+V source for the other to splice into.
                  Thanks again for the info.
                    There is a 12v power source you can tap into, inside the black box on the firewall. I've used this for my DCC setup. I'm sure there might be something closer in the harness but this might be worth looking into.
                      Noobie here, what's a DCC setup? I was looking more for a power source on the firewall plug that goes to the ECU. I need to probe where the power comes from on the EX to get an idea of where to look. I like to keep the electrical as clean as possible, lord knows months from now I won't remember where I sourced power from.
