LED Lights Keep Blowing Fuses
    Sup guys.
    A while ago, I installed my LEDs in my new car but for some reason, it keeps blowing the fuse for the interior lighting. This is now the second time in two days. My old car didnt have this issue at all. I ran those LEDs on my other car for a long time with no issues.
    What could be causing this?
    Thanks guys
    Wrecked, Revived, and still Rollin'
    Check out my MRT!
    The most unique "modification" these days is a full restoration. Take a 20+ year old Honda and make it look brand new... and it'll be more impressive than the guy with the stock-block turbo and plastidipped steelies.
    Originally posted by High5er View Post
    Sup guys.
    Thanks guys
    Did all of the oem bulbs work before the swap? The oem ones ever blow fuses?
    RIP my last two CB7s.
    New rides:
    '82 Volvo 245 drift project
    '87 Volvo 244 daily
    Born2DieApparel.com
      The OEM bulbs worked fine. Thats why Im confused. Arent these supposed to draw less?
      Also, just out of curiosity, are you a funky ball of tits from outerspace? lol
      Check out my MRT!
        Interesting. Yes, they should draw less power. If you can't get the same result with the OEM bulbs then those bulbs could be defective. LEDs seem get weird when they have a short or burn out.
        I am not just any funky ball of tits from outer space, I am THE funky ball of tits from outer space.
        New rides:
        '87 Volvo 244 daily
        Born2DieApparel.com
          some brands of LED's arent polarized and some are. It might be tedious but you might have to check and see whats + & - on the harness and then double check whats + & - on the bulb's and rotate them to the correct polarity.
            Im sorry im not up to speed with the electrical lingo, but Im assuming youre talking about how they only work one way?
            I feel like it has to do with my Dome light. The switch on that thing is broken as hell. I popped another today so Im going to swap the dome lights. After that, its on to trial and error with the courtesy lights.
            Thanks!
            Check out my MRT!
              Probably worth adding just in case that you need to use the correct fuse for the application. Not a 10 amp in place of a 15 or vise-versa.
              New rides:
              '87 Volvo 244 daily
              Born2DieApparel.com
                Yeah it calls for a 15A fuse and Ive gone through three. Ive already replaced my dome light assembly, and Im going to check my courtesy lights today.
                Check out my MRT!
                  The leds are usually polorized but wont cause the fuse to blowm. It just wont turn on. You can tell its not an issue fause it works for a while so its not a polarity issue.
                  Imo I believe that its the leds itself...cheap quality and internally they short out. Especially since with your oems you were fine.
                  Retro!
                  Hater
                    Well the same LEDs were used in my other CB and they worked fine. Also, I picked up these LEDs from Gluxlite. I don't think they're cheap. At least I'd hope not.
                    At this point, the dome light has been replaced, all lights tested, and the fuse is popping right when I put it in. No lights are on, but the damn fuse pops right when it touches. This is so irritating. I have little to no electrical experience.
                    Check out my MRT!
                      Gluxlite is just cheap stuff sold at an expensive price. Just know what youre buying.
                      No lights are on because the fuse is out? Or is the car running or lights on when you put the new fuse in?
                      Try putting in regular bulbs and put in the fuse see if it still blows. If it does you know its not the bulbs. Its the wiring.
                      C-3PO's MRT USDM yo!
                        Take out the dome then put a fuse in. If it doesnt blow the put the dome light in. If it blows then its your led.
                        If it did blow with ni dome light you may have to do a process of eliminatiin on everything in that circuit.
                        Retro!
                        Hater
                          Yeah Im going to try and see if the incandescent lights make a difference.
                          That's pretty much what I'm going to have to do
                          This point. It's raining bad today so I gotta try it if it clears up.
                          Thanks for the help guys!
                          Check out my MRT!
