I have a 93 accord lx and swapped it with the jdm f22b dohc.. I have looked around and can't seem to find the timing spec everything is its the same as the h23.. is this true ? Can I get the timing spec for my motor please thank you.
f22b dohc timing spec
Not sure if this helps go down to the "Internal/External Coil Issues"
http://www.cb7tuner.com/vbb/showthread.php?t=81303Last edited by cky413; 12-11-2014, 06:40 PM.
treat it as if an h22a or h23a dohc vtec. theyre pretty much the same engine anyway. you can be lazy and center the distributor in the middle of its swing, reset the ecu, and the computer will adjust accordingly. otherwise, get it up to temp then shut it down and restart with the service connector shorted and break out your timing light.
Originally posted by illinois_erik View Posttreat it as if an h22a or h23a dohc vtec. theyre pretty much the same engine anyway. you can be lazy and center the distributor in the middle of its swing, reset the ecu, and the computer will adjust accordingly. otherwise, get it up to temp then shut it down and restart with the service connector shorted and break out your timing light.
