Thread Tools Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
Old 10-13-2013, 02:45 AM   #1
heretoaskstuff
heretoaskstuff is cool... so far.
Best ecu for f22a4?
So I just found out that the reason my car will not go past 5,500 rpm's is because the ecu is set to cut back at 5,500. What ecu could I put in to help gain more power and of course redline. I'm not going to be bouncing off of it, I just like for my car to run that high and not be bounded to 5,500. I heard the p12 ecu would help with this?
heretoaskstuff is offline   Reply With Quote
Old 10-13-2013, 03:14 AM   #2
accordztech
accordztech is cool... so far.
Send a message via AIM to accordztech
You need to pay to play. Headwork , cams are just a start of a long process. You have a sohc....dont expect much at that rpm. After everything you won't be happy.
Drop a h22 in or boost yours.
Retro!
Hater
accordztech is offline   Reply With Quote
Old 10-13-2013, 03:20 AM   #3
heretoaskstuff
I'm already getting a level 2 cam from bisimoto and pro valve springs, I have a jdm obd1 h22a but I don't know what all I need to drop it in there. But for the f I want a n/a build. I have enough money to make it work, but it'll be a little every week.
Old 10-13-2013, 05:44 PM   #4
accordztech
Why not just boost it and you wont have to redline it.
Retro!
Hater
Old 10-13-2013, 06:36 PM   #5
deevergote
Don't call me dude.
It shouldn't cut off at 5500. If it's doing that, something is wrong. Another ECU probably won't help that.
For a stock F22A1 or F22A4, a P12 will indeed help. However, if you're getting a Level 2 cam, don't waste your money on a stock ECU. Save for a chipped P06 with a proper tune. No stock ECU is going to like a Level 2 cam.
Old 10-13-2013, 07:10 PM   #6
heretoaskstuff
There's a tuner shop around my area who does tune ups and chips, could I get them to tune my pt3 to the level 2 cam? Or would I need a whole new chipped ecu?
Old 10-13-2013, 07:32 PM   #7
pupildel
Accord of the Month - February 2014
pupildel is cool... so far.
Send a message via AIM to pupildel
no you can not you need to get a whole new chipped ecu didnt Deeve just state that no stock ecu is going to like the L2 cams
pupildel is offline   Reply With Quote
Old 10-13-2013, 07:41 PM   #8
heretoaskstuff
I misunderstood, but now it's time to searh for the right ecu.
Old 10-13-2013, 07:43 PM   #9
deevergote
Don't call me dude.
The PT3 CAN be tuned, but the software to do it is limited and very poorly understood/supported.
The P06 found in a 92-95 non-VTEC Civic will be easier to use, as they are very well supported and understood.
A chipped ECU is basically just a blank slate, so once you have a compatible ECU, it doesn't matter what it is... as long as it can be tuned.
Old 10-13-2013, 08:54 PM   #10
heretoaskstuff
Alright. So, get a p06 ecu and get it tuned to the level 2 cam?
Old 10-14-2013, 07:11 AM   #11
deevergote
Don't call me dude.
That would be your best bet. Make sure you have a tuner that knows how to tune Hondas. That, or start studying and collecting the tools necessary to do it yourself ($300 or so will get you a good basic tuning setup from moates.net.)
If you want to go the self-tuning route, I suggest practicing before installing the cam. A bone stock F22A is a very good platform to learn ECU tuning. The low compression ratio gives you a wide margin of error.
Old 10-14-2013, 01:41 PM   #12
heretoaskstuff
It's just $300 for a basic self tuning system? I was expecting it to be a lot more, lol but I'll learn but let someone else who knows do it the right way. Thanks, Deeve!
Old 10-14-2013, 07:42 PM   #13
deevergote
Don't call me dude.
It can be much more. $300 was just the estimate I pulled out of my ass when thinking of the basics... wideband o2 sensor, vacuum gauge, datalogger, chipping kit, P06 ECU, and a burner (without checking prices, I think those things would come to roughly $300 if you shop smart.) That is, of course, assuming you have a laptop to use already... not that you couldn't pick up a crappy old used laptop for cheap. Tuning doesn't need anything fancy.
You could always improve such a setup with fancy toys such as a realtime emulator such as the Ostrich, and other sensors, like an EGT sensor (very useful in tuning.)
I'm no expert in tuning, but I've researched and talked to enough people that are to learn the basics. I'm actually excited to really dig into my own ECU (I have a set of Delta 272 cams waiting to go into my H22A... making it the perfect time to retune!)
Old 10-14-2013, 07:45 PM   #14
heretoaskstuff
Awesomeee, well time to start researching ecu tuning and shopping!
Old 10-15-2013, 07:36 PM   #15
heretoaskstuff
Hey Deeve, will this help me tune the p06 ecu for the cam? : http://www.moates.net/demon-hardware....html?cPath=33 I also got a p06 ecu from my friend for $60.
Old 10-15-2013, 07:56 PM   #16
deevergote
Don't call me dude.
$60? Shit... I was recently selling one for $50 shipped! Some friend...
That package would work. More advanced than the basic setup I described above, but definitely capable. Neptune is powerful and well-supported. The Demon, if I recall correctly (I didn't read closely) is also a real-time device, so you don't have to constantly burn chips. I'm not 100% on how it works, but that's a good setup for sure.
Old 10-15-2013, 08:46 PM   #17
Nyne521
Nyne521 seems to have made some friends! Nyne521 seems to have made some friends!
Send a message via AIM to Nyne521
my car also wont rev past 5.5k but i don't believe it has anything to do with my ecu... if that is still your main concern, i'd work on figuring out the problem before tuning.
Nyne521 is offline   Reply With Quote
Old 10-15-2013, 09:26 PM   #18
deevergote
Don't call me dude.
Not revving beyond 5k should be an ECU issue.
Old 10-15-2013, 09:47 PM   #19
heretoaskstuff
Awesomeee. But yeah I kinda just threw the $60 asking price out there and he jumped for it. But idk why it won't go past 5500. All sensors are fixed, I'm not getting any cel codes. My battery light is on though, I'm not sure why. But I'm definitely getting the tuning setup now.
Old 10-15-2013, 10:58 PM   #20
HappyGilmore
AKA Gillymomo
HappyGilmore seems to have made some friends!
Send a message via AIM to HappyGilmore Send a message via MSN to HappyGilmore Send a message via Yahoo to HappyGilmore Send a message via Skype™ to HappyGilmore
Limp mode perhaps? I am also with Deev on this one as well, I would try a different ECU and see what happens.
The CB7 Collector.
92 LX Coupe F22A1
97 LX Wagon 5-Speed F22B2
92 EX Sedan F22A1
HappyGilmore is offline   Reply With Quote
cb7 , ecu , p12 , redline , rpm
