Alright guys riddle me this one.
Motor: h22a
Tranny: m2b4
Mods: Short ram intake, blacktrax spacer, hondata intake manifold gasket, Tri-y slip fit header, high flow cat, DC cat back.
The issue:
Car starts up fine but doesnt have the high idle with the slow drop that it used to. It fires up and revs to about 2k and drops instantly to about 300 and almost stalls. Then goes to about 1000 and hangs out around 750 when it calms down.
When I drive off easy on the throttle it seems to almost get stuck somewhere just under 2k rpms and I have to get on the gas more to get it "un stuck". I notice this through out every gear when I'm just cruising.
If I get on it hard sometimes to power is just gone. It will accelerate but it feels like Ive got 100 hp max.
Sometimes its fast as hell and it will scream all the way into VTEC and then around 6400 it feels like it gives up and the power is gone.
I know thats kind of a lot to take in but thats the best way to describe it. Any ideas?
Clutch and flywheel are all new so I dont think its slipping out of gear, it doesnt feel like that anyway.
I should add that I unplugged the O2 and drove around and it doesnt bog at low rpms but still falls on its ass up in VTEC. Could air be getting in or out of the slip fit and cause this, hence the reason it ran different with the o2 unplugged?
Motor: h22a
Tranny: m2b4
The issue:
