oneoffaccord : 1991 Civic DX
    Prothane shifter bushings came in today. Might installed the kit, shift linkage and exhaust aswell
      Got a couple of updates here. Got the shifter bushings the other day,went to install them went some what well. The rod with circle part went in fine, im guessing this part is the conversion kit, well the other half of the kit is missing. So now i have to cut and weld a factory DA part to make it work.
      Picked up the rest of the fuel setup today. Got that all squared away, looks great. Also picked up these Duralast lower ball joints aswel, now all i need are the wheel bearings and im set.
      Prothane shifter bushing kit
      Earls Fuel Filter and fitting
      Ended up using a factory fuel banjo fitting that i cut for the fuel rail, also wire wheeled it before hand
      the finished project
        Got a couple of things today, went to autozone picked up the front wheel bearings and the coolant bypass house. Struts came in today. Taking the knuckles, wheel bearings, lower ball joints, hubs, struts, strut mounts tomorrow to work together everything installed.
        Duralast wheel bearings and lower ball joints, painted knuckles, and hubs
        Tokico Blues
        Used SKUNK2 coilovers, yea they are beat looking but they were free
        Mod list updated
          bearings, ball joints and hubs installed. will be installing the rest of the suspension tomorrow
            Clean them up, can't wait to see them on the struts
              thanks man.
              Ran into a problem today, lower forks dont fit the struts. i think the forks are for a EG civic. now i gotta get another set of forks that are made for EF civic
                junkyard if u can find it there. Clean it up an do wat u do best man. Diy it.
                  just ordered a set from cali for $50
                    Got the struts all done and mounted in, installed both front and rear strut bars. Installed the rotors, calipers, and pads on the knuckles. So when its time to install them i can just installed and be good.
                    Also painted the front crossmember gloss black
                      Take it down the track when u r done at least once. Well maybe a few times =)
                        if i have time i will
                          Looks good man. Get it done. Like the new process.
                            thanks sir
                              Big thanks to [CP]Mike for coming thru and soldering my injector wires.
                                More updates tonite, sparyed SEM undercoating on the front wheel wells, installed the front crossmember, Skunk2 upper control arms and last are the knuckles. Wish i had the forks so i can at least move the car around more updates coming soon
