My spark plugs get a little bit of oil on them wen i check them from time to time...is it because of the head gasket or could it be the piston rings....someone let me know and the spark plugs seem to be worn already only 5k on them
Spark Plugs And Oil???
This topic is closed.
go to auto zone and get a valve cover gasket. it comes in a set and there are these O rings that go around the spark plug holes. the ones you have are probaly bad.
as for the spark plugs wearing out. you may be running to rich or too lean. or maybe somethin else. look in the back of a hyanes manual. it shows you what your spark plugs should look like. and also what it looks like in differnt situations
http://www.cb7tuner.com/vbb/showthre...park+plug+tube
its your spark plug tube seals like he said try that linky its the diy
