Wow, that's something you don't see everyday. I was really worried that this would not turn out well, and we would have to put Collective into the "Don't go to this mechanic" or "Don't do business with this company basket. That sure says a lot about the character of the mechanic. Humility is hard to come by these days, so it seems there is still hope for us!
Restless : 1992 Accord EX
*** Think of others before thinking of yourself. ***
MRT
Selling on Ebay!
15.10 @ 90.42mph
Current fastest Laguna Seca Lap: 1:52.889
Main relay replacement installed
My main relay replacement came in the mail yesterday evening. Once I swapped out the old one with the new one, I was able to get it up and running again. I was a bit worried though on the first initial start up because it wouldn't turn over, but after the second try it started right up. Going to change the O2 sensor here in a bit, then see what kind of refund I can get from Collective. The real test though for the main relay will be these next couple of days when it's hot out since it'll be under the most stress.
Out with the old in with the new.
I also, took it upon myself to take a look at the closed loop tab in SManager when it was hooked up to my ECU so I can have an idea of what I'll have to do instead of driving up to UMS Tuning just for them to do it. I believe all I'll have to do now is under the "closed loop operation" drop down just switch it from open loop (closed loop disabled) to closed loop - stock sensor (narrowband) and just click the box for Disable O2 heater so that it's enabled. But for now, I'm a leave it how it is and call UMS Tuning later on today so I can make sure I get this done right even though it seems rather simple.
After replacing my main relay, I had the car running good for about a week, but eventually my fuel pump gave out and my clutch master cylinder the week after that. So I decided to get a new fuel pump and some other little fuel goodies. Also, after replacing the fuel pump I couldn't get the car to stay on with the Hondata ECU. I'm thinking it's because of the previous tune recently, but as of now I'm back to my chipped p28 again.
Originally posted by Raf99 View PostNice car. & this Collective place, stop going there. Fix the repairs you can by yourself and take it to someone else for repairs you cannot fix. For tunes and more intense stuff save your $ and go somewhere else. That Collective shop is goofing you around and they know it!
Originally posted by Restless View Post*** Think of others before thinking of yourself. ***
MRT
Selling on Ebay!
15.10 @ 90.42mph
