I have a 92 honda accord coupe ex auto. Old trans had steady d4 light and would only move in 4th gear. Had the trans replaced recently and now I start the car and it has a steady d4 light on until the car has sat running for awhile. Maybe 15-20 minutes. While the d4 light is on I manually shift into 1rst to move and once up to decent speed shift up a gear but it goes into 3rd. Just 1rst and third gear when the light is solid. Once the light goes off the car shifts perfectly fine. Im ready to take the car back to the shop. Wth could it be? Let me add they put my old solenoids on the new trans.
transmission issues chaos
If the D4 light is coming on, and the transmission isn't shifting, then there's something wrong. If there are no codes being thrown when you jump the service connector, then the TCU itself is likely bad. You can repair it if you know what you're doing, or you can replace it.
Most likely, that's the issue. You'd be getting a code otherwise.
