Is that leather I see?
New guy from New zealand!
Thanks
Sure is Leather.
Had a few more bits turn up that were ex japan.
Included here is an LMA spring for the euro R head as one had been pinched out of it before I got it, New valve stem seals, All the seals related to the oil pump, Crank seal, front balance shaft seal, dipstick o ring, rear balance shaft plate o ring, Axle seals for the T2W4 box, And theres some more bits floating around too.
Have decided to get an Innovative mounts adaptor mount as the Manual mount bracket is NLA Oh well will make the job alot easier.
I still dont know what axles I'll get away with? Do I HAVE to run CB manual axles and intermediate shaft or can I use BB1/4 or CD5/6 manual axles?
Yes, the CB Accord axles are what you need to run. Why is this a perceived issue?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Zombine View PostAnd a CB7 accord, which is 99% factory. Nearly fully optioned from new, and bought by my grandfather. Only mods at this stage are a nardi wheel, and some sounds to keep me entertained - It's my daily driver.
The CB has an F22Z1, an auto gearbox, leather interior, ABS brakes, the lot. Only thing that wasnt optioned from the factory was the sunroof, as my grandmother had rust issues on her CA accord and they didn't trust them.
Correct me if I am wrong but your CB seems to be made in NZ when the country still had a car manufacturing industry.
The engine number seems to be for the NZDM.
Originally posted by Zombine View PostAfter getting bored with the auto gearbox, I decided to swap it to a manual (Which is why I'm here, getting info I need for the swap ), And decided, Why not drop an H22A in at the same time.
Great choice of mod upgrade thoughLast edited by JDMDriver; 04-02-2015, 08:10 PM.Rides:
Accord
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" - Black
Prelude
Originally posted by JDMDriver View PostThe Accord's condition is Fantastic!! Very original!!
Thanks, Yes it is. They were built in Napier. Painted in NZ, used NZ made carpet which is MUCH nicer than imported ones, NZ made wiring, NZ made glass, alot of kiwi made parts on it which is quite a cool thing
This only applied to the NZ new ones though It was the last CB accord that Waikato Honda ever sold, Now I work there :P
Thanks
I have decided to go the aftermarket mount for the gearbox, being the innovative option.
https://www.innovativemounts.com/Pro...ductCode=29324
So my parts supplier has that coming in for me on a sea freight order, so will be a couple of months before it gets here. That's fine as it allows me to gather the last of the rest of the bits I need.
Took half a day off work and went back to pick a part, where there was a manual CB.
Got the clutch pedal:
Brake and throttle pedals:
Shifter boot and bracket:
Passenger side (LH) axle:
Half shaft:
On a side note, My DC2 was in a local magazine, NZ performance car, In a small "under construction" part
If you guys want to see more of my DC2 I can post that aswell, But thought I'd leave it out being a CB related forum :P
I had planned on changing both my outer CV's as they are both clicking, And I need to on the new LH side axle as it came out of a non ABS chassis. All CV joints will also recieve new boots
Things that are left for me to aquire are, clutch kit (Already have H22A flywheel, Which I assume will fit my F22 motor?), Clutch master and slave cylinders (Will be going new). And a few other small things, like shift cable clamps and clutch fluid reservoir and soft lines etc.
Not sure how far away my H22A shortblock is going to be so its gone low priority for now, Main focus for the moment is to do the manual swap, Then slot the H22A in when its ready
Thanks for reading!
Hey guys, Things are coming along nicely with the CB.
Should have the conversion mount this week.
Will get an oem spec clutch kit, new master and slave cylinders too this week with a bit of luck
Also went back to pick a part, and got the clutch line from the master cylinder, to the gearbox, Which completes the line.
Also got the clutch fluid reservoir and all the associated brackets.
Have organised for a workmate to give me a hand to do the swap on the 20th, which gives me a few weeks to make sure I have everything I need
Sorry no pics, will make sure I get some during the swap though :P
Thanks for reading!
For those who care, A turbo, manifold, downpipe and wastegate came up for farr to cheap for the DC2, So should be picking that up this week too!
So bit more of an update, The conversion is 99% complete, the remaining 1% is me wanting to rectify the harshness of the aftermarket mount.
The ratios of the new gearbox are great and give me alot more available torque, and the LSD is a good bonus too (Y)
Old AT removed
Passenger side axle refurbished, Cleaned and regreased CV joints, and new CV boots
Euro R box bolted in
manual starter I got from pick a part
All back together
New shifter boot and gearknob I got from pick a part
Will get a photo of the underside when its on a hoist next
You'll have to let us know how that F responds with that t2w4 transmission.Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
Thanks guys
Because the ratios are so short on the f series, it gives me so much torque. 2nd will top out at around 80kmh,3rd tops out at around 115kmh and 4th tops out around 150kmh! So definitely very short, certainly makes it get up off the line quickly
Forgot to mention I've ordered an iacv adaptor for my euro r manifold too, hopefully will have enough firewall clearance!
Here's a short video of it, not revving right out and shifting nicely on the box.
https://youtu.be/XCpFaNTnhj4Last edited by Zombine; 06-21-2015, 01:29 AM.
