F23A swap with power steering
    I did the F23A swap in my CB7 has anyone figure out the power steering?
    The f22a pump and bracket will not work on the f23. You will need to get the power steering pump, bracket and hose off of a f23. It may require a little modification to bolt up to the rack as far as rebending it
    I am 95&#37; sure Parts off of a 5th gen accord should work too
      got a reman rack just tryed the 94 power steering pump and bracket. the line don't hook up.
