H22 CB9 Failing Smog
    Hello, recently took a H22 swapped CB9 to the smog station today. Passed inspection and failed pretty badly on the emissions.
    Here's what I got.
    15 MPH - Fail (Gross Polluter)
    - CO2(&#37 l Meas= 10.15 l
    - 02 l Meas= 0.00 l
    - HC(PPM) l Max= 78 l GP= 286 l Meas= 323 l
    - CO(%) l Max= 0.72% l GP= 2.22 l Meas= 7.04% l
    - NO(PPM) l Max= 778 l GP= 1973 l Meas= 387 l
    25 MPH - Pass
    - CO2(%) l Meas= 14.60 l
    - 02 l Max= Meas= 0.00 l
    - HC(PPM) l Max= 61 l GP= 236 l Meas= 59 l
    - CO(%) l Max = 0.60% l GP= 2.10 l Meas= 0.12% l
    - NO(PPM) l Max= 717 l GP= 1773 l Meas= 163 l
    The motor is a JDM H22A stock besides AEM SRI and DC headers.
    Right now i'm experiencing terrible gas mileage.
    Did a 120mi trip up to Sac and got 23 mpg with A/C.
    Besides that, no check engine light or anything out of the norm.
    Ok. I kinda shot myself in the foot prepping.
    I didn't warm up the cats. Probably hit 30mph tops coming to the station haha.
    So I'll come in hot next time.
    Besides that I have a feeling the O2 sensor might be buggered up.
    I'd like you guy's input.
    I'll check the plugs tomorrow and do an oil change. What else do you think I might be able to do to pass?
    Honda user manuals
    Halp!
    New o2 sensor (Denso or NTK only), new plugs, new cap, new rotor, warm cat... what ecu are you running?
      CO emissions are a good surrogate for air/fuel ratio (almost all of the excess fuel is emitted as CO). Your 7% CO at 15 mph says you are running rich.
      Might be an O2 sensor problem. Might be a tuning problem. How good was your tune? Are you sure that it is programmed to run in feedback mode except at high throttle openings?
      And I assume you have a manual. It wasn't being lugged in 4th gear at 15 mph, was it? That would cause high throttle openings and enrichment.
        Do an ignition tune up, o2, and retard the timing a little bit. So you know, if you retard the timing, NOx will go up. HC/CO go up, NOx goes down, and vice versa.
