What is this bad clutch pedal noise?
    When the clutch is released you can hear this noise
    When you push in the clutch pedal the noise goes away
    I made a thread about this before but now i have a video.
    Sounds to me like its the throw-out bearing.
      But that doesn't make any sense. The throwout bearing is used when you push in the clutch pedal. When you release the clutch the throwout bearing is no longer being used for anything.
        When you press in the clutch peddle you separate the engine from the tranny. My guess is there is an issue with the tranny, like low on oil or something broken. Or something is broken with the clutch disk or pressure plate.
        My swap thread
        Main relay proplems?--DIY
          Mine makes the EXACT same noise, and I installed a new clutch kit with throw-out bearing when I did my 5-spd swap.
          I have always assumed it to be the throw-out bearing.
          29 MPG in town ~ ?? MPG Highway
          "how can I make my car unique, just like yours?"
            i wouldnt worry about it too much, it does sound transmission related. probably a noisy bearing
            I <3 G60.
              So you don't think anything will fail in the near future?
                i dont think anything will fail.. my cb7 makes the same noise as yours and almost every cb7 i know
                  I had the same noise on my 03 SRT-4 only about 10 times louder. I beat the heck out of that car and it never gave me issues. All I was told was my clutch was going out drove it for a year before I got rid of it and still no issues.
                    its deffenetly a throw out bearing tip...but get it fixed as soon as u can man..mine did that noise and now it soooooo loud and nasty and it fucked up my clutch....
                    my new turbo build
                      How is it a throw out bearing?
                      It doesn't make the sound when you push the clutch pedal down which is when the throw out bearing is engaged.
                        That's when the load is on the input shaft. That's gonna be the trans input shaft bearing right behind the throwout bearing. I don't remember if you can see it though.
                          Quoted for truth. Input Shaft Bearing.
                          You cant see it, its in the case.
                          1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
                          1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
                          My Workout Log
                          Originally posted by Leung
                          Well, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
                            So if this bearing fails the whole transmission goes boom?
                              Its not the throw out cuase my throwout went out last month and it made the noise when clutch was engaged and got so bad that the car would shut its self off
                              1992 lx sedan-christy-my black beast
