Old 10-01-2008, 09:27 PM   #1
Jon
Jon is very helpful Jon is very helpful
Oil dripping, possible ideas?
I have a oil drip and it seems to be coming from right around the timing belt cover (lower not upper). So something is leaking and the oil is migrating.
From a quick visual the valve cover seems to be fine, front and back show no signs of leakage. Same goes for the oil pan, it's as clean as a whistle.
I haven't pulled the driver's side fender well liner off yet to see if I can't spot where it's coming from, but I will be doing that in the next day or so.
My question is, does anyone have a rough ideas of where this oil drip/leak could be coming from? I know... it's like diagnosing an illness over the phone, kinda hard to do. I'm just trying to come up with a few possible ideas before I start taking stuff apart.
Jon is offline   Reply With Quote
Old 10-01-2008, 09:27 PM   #2
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
Balance shaft probably.
wat?
C91BLX7 is offline   Reply With Quote
Old 10-01-2008, 09:29 PM   #3
H22Artman
H22Artman is cool... so far.
sounds like any number of the seals behind the timing cover could be leaking.
crank, cam, oil pump, etc.....
pull the cover and its likely that you will find your problem.
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
H22Artman is offline   Reply With Quote
Old 10-01-2008, 09:30 PM   #4
batever
batever is cool... so far.
Hi, frootloops!
maybe one of the seals under the timing covers--balance shaft seals or even camshaft seal? Or maybe the balance shaft access bolt has loosened and some is leaking out under the sealing washer.
good luck.
batever is offline   Reply With Quote
Old 10-01-2008, 10:09 PM   #5
Jon
Thanks for the input guys.
I'll pull the cover off, see what I have and report back. Just not looking forward to doing it right now, I'd rather finish up my intake swap...
Old 10-02-2008, 01:57 AM   #6
QUICKwitit
QUICKwitit is cool... so far.
Send a message via AIM to QUICKwitit
might as well do it as once while you do the intake swap
QUICKwitit is offline   Reply With Quote
Old 10-02-2008, 02:09 AM   #7
blackice
blackice is cool... so far.
definitely read this thread http://www.cb7tuner.com/vbb/showthread.php?t=16228
Retired 1990 Accord LX Coupe
Project 240SX
Originally Posted by chillin943
anyone kno if i can just make a hot wire for v-tec off the horn??
Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, rosko
blackice is offline   Reply With Quote
Old 10-02-2008, 02:34 AM   #8
Leung
Leung is someone to admire Leung is someone to admire Leung is someone to admire
Originally Posted by blackice View Post
is that about the camshaft seal retainer clip? i figured everyone would have ran out and had one installed already.
to the OP which engine do you have?
theres a girl i work with that says she's losing oil somewhere in the rear, so i'm thinking it's the oil cooler plate that is behind the oil filter on her '93 SE. i just need to make my way over there to visually inspect it.
Leung is offline   Reply With Quote
Old 10-02-2008, 09:13 AM   #9
Jon
Yep. I'm going to have a ton of shit torn apart so a lot of gaskets and seals are getting replaced.
I have a A1. Drip just started happening so it's getting fixed asap. I'm making everyone drive me around/do stuff for me so it can sit on the driveway.
Old 10-03-2008, 01:36 PM   #10
Jon
Does anyone know if there is a gasket set that TASAuto carries that has all of the necessary gaskets/seals in it to do a timing belt change, water pump, balance shaft seals, camshaft seals, etc.? I've just been going through adding all of the different gaskets/seals to my cart and I honestly think I'm missing a few.
Old 10-03-2008, 01:56 PM   #11
deevergote
Don't call me dude.
I don't know if they have a complete set... but I'll talk to Stephen and see if we can make it happen
Old 10-03-2008, 02:14 PM   #12
Jon
Thanks, that would be awesome. Let me know if you can make it happen.
Old 10-03-2008, 10:26 PM   #13
batever
i believe all you need is camshaft seal, 2 balance shaft seals, crankshaft seal if you are going to do it. Front balance shaft seal retainer if you don't have one. If you don't know and you have a local honda dealer, I'd say don't get it and if you discover it's not on, just get it from your local dealer. In any case it's like 6 bucks.
timing belt
balance shafts belt
plus water pump which comes with its own gasket.
that's it.
Old 10-03-2008, 11:07 PM   #14
Jon
timing belt
balance shafts belt
that's it.
Thanks for the help, I appreciate it.
Yes I have a local Honda dealer, I'll hit them up for the shaft seal retainer.
Old 10-03-2008, 11:10 PM   #15
rodriguezyadir
rodriguezyadir may have said something they shouldn't have...
you have to buy new seals for it that's what it is
rodriguezyadir is offline   Reply With Quote
Old 10-03-2008, 11:22 PM   #16
Jon
What?
I'm getting all of the seals and gaskets from TASAuto. When I pull it all apart I'll see if I have a retainer. If I don't I'll hit up my local Honda dealer.
Old 10-04-2008, 03:22 AM   #17
GangstaCB7
GangstaCB7 is cool... so far.
>it could actually be ur tranny, that happened to me
GangstaCB7 is offline   Reply With Quote
Old 10-04-2008, 09:30 AM   #18
Jon
It's definitely oil and not tranny fluid, and boy am I glad it is oil...
oil , oil drip , oil leak , timing
