Old 02-23-2015, 08:18 PM   #1
bizzle2288
bizzle2288 is cool... so far.
Question h22a1 - h22a4 oil pan
Just bought a 92 ex sedan with an h22a1 swap and the oil pan is crushed. I have am extra H22A4 aluminium oil Pam along with the pickup, can I get away with using the pan for the a4 or do o need to purchase a new oil pan?
bizzle2288 is offline   Reply With Quote
Old 02-24-2015, 03:28 AM   #2
lindiz
lindiz is cool... so far.
An H22A4 aluminum pan will work just fine, and you don't need an oil pan rubber gasket since the block and pan will heat expand equally when they are the same material. Honda themselves just uses liquid gasket (Hondabond for example) on aluminum pans.
lindiz is offline   Reply With Quote
Old 02-24-2015, 07:50 AM   #3
djcaz_aom
djcaz_aom seems to have made some friends! djcaz_aom seems to have made some friends!
You can use the aluminum pan. Just get a tube of Hondabond and the small rubber gasket that goes on the transmission end. Also, the pick ups are the same between H22s.
djcaz_aom is offline   Reply With Quote
Old 02-25-2015, 11:44 AM   #4
bizzle2288
Question
Thanks guys, where can I get the little rubber gasket on the transmission side?
Old 02-25-2015, 12:19 PM   #5
djcaz_aom
At the dealer. The part number is:
11251-P5K-000
Old 02-25-2015, 05:33 PM   #6
bizzle2288
Thumbs up
Nvm found it on estore.Honda.com Thanks for all your input, helped a lot.
Old 02-25-2015, 05:34 PM   #7
bizzle2288
Thanks
h22 , h22a1 , h22a4 , oil pan , swap
