Thread Tools Rating: Thread Rating: 3 votes, 2.67 average. Display Modes
Old 09-17-2019, 11:17 PM   #21
CbNewbie
CbNewbie is cool... so far.
Well, Motors in, hooked up. NO Spark :/. I may have not gotten all the grounds hooked up. I know i need the mains, ECU Ground (?), Battery (Got it), Trans (Yep), VC (Yessir). Are there any more that I may be missing that wouldn't allow it to spark? Thanks!
(Distributor is NEW.)
CbNewbie is offline   Reply With Quote
Old 09-18-2019, 07:47 AM   #22
Rilas
Thermostat housing ground. Which is one of the main grounds for the ecu if I remember correctly. Will cause all kinds off issues, if it's not hooked up.
Old 09-18-2019, 02:19 PM   #23
CbNewbie
Okay, as far as that one goes the very bottom bolt on that broke the head off, am i able to connect it to any of the other two bolts? If so, i did it and it still gave no spark. I'm considering a new distributor (In last post i meant new as in new for the car, it was a junkyard one so it could be bad. would go to autostore to buy a new, new one.) but I'd also like to figure it out.
Took a multi-meter to the grounds (i suppose i did it wrong/right) touching positive terminal and i got a full reading on all the grounds. 12v(ish.).
Its probably something easy/stupid but I've never done something like this before so i'm pretty stuck. Any ideas would help, and I've got a mechanically inclined friend coming to help out tomorrow. Hoping to get it running soon
Old 09-24-2019, 05:14 AM   #24
Grumpys93
I always refer people to ericthecarguy on YouTube. He has a great video on how to troubleshoot no start and it’s even on a Honda. Hopefully you figured it out, if not let us know
~Nick~
Old 09-24-2019, 02:06 PM   #25
G. Wiffington
So what broke? The camshaft or cam gear?
How are you verifying there is no spark?
Is there no sound at all when trying to crank it?
Does the fuel pump prime?
Any Check Engine Lights??
Keep Pushing..
