Grounding Aftermarket System
    can somebody tell me a good place to put my ground wire around the trunk area?
    pretty much any bolt you can loosen and wrap a wire around will work fine, all you have to do is make sure the metal is clean. some people will recommend certain bolts over others, but the whole chassis is one big ground, so it really doesnt matter.
    My Cars: 2006 Ford Freestyle - 1990 Accord EX - 2001 Accord EXV6 Coupe - 1967 Impala "Metallicar" (for the wife)
      Make sure you use a ring terminal and put the bolt threw the terminal. A good ground is key. You want to sand the area down to bare metal so there is good contact also.
        ok thnks for the advice guys!
          Get to the welded subrame if you can rather than grounding to a bolted on sheet metal part.
            The shorter the ground wire the better too. And if you have other grounds in the area its best to use that ground (have one main ground instead of 3 smaller spread out ones).
              I have my amps grounded to the strut tower bolts/nuts.
              Click picture for MRT
              Sparkin CB7
                I did mine on the back seat bolt on the passenger side, gave her a good sanding and it works for me.
                MRT http://www.cb7tuner.com/vbb/showthread.php?t=202004
                1992 Accord EX(Canadian)Seattle Silver sedan
                  I did mine on the fuel sender unit ground just behind the rear seat under the trunk carpet. Just used the same bolt so I didn't have to drill a new hole. Used a dremel with wire wheel to make sure it made good contact.
                  So far its working well.
                    Best spots would be at the strut tower or at the bumper bolts they're bolted to the frame...
                    My 90 coupe Mr thread....
                      I always drill a bolt through the fender well, easy to get a nut on it by reaching behind the tire. Wire wheel it top and bottom. Tighten the bolt and nut up, the tack weld the nut in the fender well so it's easy to remove the bolt, then hit the inner fender up with some spray on bed liner
                        That, sometime i scrape the area with something sharp, and then sand it down to make sure it's bare metal.
                          If you grind a spot down to bare metal make sure you seal it some way to prevent rust. It doesn't matter if you put a clear coat on it or rattle can it just seal it. Well this is the Minnesotan in me I guess. Rust is my biggest obstacle.
                            google: "site:cb7tuner.com ground amp trunk cb7tuner"
                            Grounding locations for trunk mounted amps?
                            Best place to ground amp in trunk
                            Best place for a ground in the trunk
                            AMP problem
                            Amp ground?
                            searching does wonders
                            C-3PO's MRT USDM yo!
                              as many guys here have said, use any bolt, i did with my CB7 when redid the entire system.
                              Worked perfectly.
