Car was stolen and not sure if engine was ruined. Leaks soo much now car becomes a smoke cloud after 10 minutes. It runs but while running it leaks badly. Only while running. One badleak is seal on oil filter. The other is that cam sprocket seal inside of the sprocket. Not sure if there are others. I have not taken lower timing belt cover off yet. Is this the result of an overrevved engine or something? Opinions please.
Second question is How would you make engine leak oil baldly like that but still run ok. Overevving creating too much pressure and blowing seals? WOuldn't valves be bent also. If valves were bent what obvious signs would i have?
Also how is that cam seal inside of cam sprocket changed? IS it just a matter of taking cam sprocket off and pushing new seal in there?
