alright, I got a Auto p12 from a member here and it throws a code 41 as soon as I install it. So I replaced my o2 sensor with a gently used NTK and reset my ecu and it doesn't go away.
Fast forward to about a week ago, got a brand new o2 sensor NTK and still the ECU throws a p12, I've reset my ecu a few times and it doesn't go away.
so the code is still haunting me, I was careful installing not to bend or strain the wires on it and honestly its just a bit annoying, from my research code 41 should go away with a new o2 and resetting your ecu...
am I missing anything? is there a way to test the ECU itself? or do I just go ahead and find another p12 that hopefully doesn't keep throwing codes?
thanks for reading.
Jesse
thanks for reading.
Jesse
