Question concerning a closed thread (Please read)
    The PT6 can't be tuned, though... just to make that clear (my previous post could be misunderstood, now that I re-read it) The PT6 is your best bet for a stock ECU. A P06 is what you'd want if you want to have it chipped and tuned.
      woo I actually thought i knew that... turns out I was right lol
      Once I actually get my motor built I'm gonna run a tunable ecu obviously (p06, p28, p72... ect)... here is my question, Is Hondata worth it?
        It depends. They have a very well designed platform, but it's only worth it if 1) you actually NEED everything they have to offer, and 2) if you or someone you know is proficient in using it. Otherwise, no, it's not worth it. That goes for any expensive engine management system (and there are some good ones out there that are worth more than the cars we're putting them in!) Hondata is very reasonably priced (and their lower models at least are really just "chipped" ECUs anyway)
        Crome and Uberdata are the usual options for budget-minded tuners on here. They meet the needs of most NA and turbo guys.
          ok, So something like crome, is that something that I could get tuned, and then play with? because I REALLY want to learn how to tune...
          the main things I was looking at Hondata for were launch control and full throttle shifts, also the CEL shift light is a cool feature
            Uberdata does all that. I have it on my P28 right now, in fact. Crome most likely does as well.
            Take a look at the ECU Tuning section of this forum (a subforum in the Performance section)
              Alright thanks, I'll go look
