ENG: Erratic Idle Fix
    I think I'm going to try blocking my Air Boost off soon, my erratic idle has returned, although the air boost valve was originally the culprit.
    I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
    "Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
    CB7: The Movie TEASER VIDEO
      this is a very good write up, alot of good information here...
      should be stickied!!
      .............................-----------------93 Ex Coupe[/COLOR]-----------------
      My CD7
        This is one of the best threads on here.
          has my writeup actually helped anyone fix their erratic idle? just curious.
            Good stuff Torqstr
            Just a couple things:
            Isn't removing the ECU backup fuse after already removing the battery cable redundant? I'm pretty sure there isn't a backup battery on that circuit...then again I don't know everything.
            But I do know that the EGR function info is incorrect. You're describing something else, can't remember the name. The EGR does just as its name says (exhaust gas recirculation) when the engine is at a high enough temp, and at certain throttle conditions.
            Regardless, the procedure was the important thing, and I think it was great. :TU:
            Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
              man i love this DIY!
              thnx
              MY 1n2 CB7
                If you tighten the fit while cold what will happen?
                I just threw some carb cleaner and snugged it pretty tight. I don't see a difference besides my acceleration pedal tighter and my car coming to a stop in drive, but that I think is brakes riding my rotors.
                No longer have a cb7.
                V6 POOOWAAAA
                lol, a buick.
                  Just wondering.... would an EGR valve from an F22 fit on an H22?
                  CD7 H22
                  CB7 H22
                  FROST WHITE CREW #33
                  Member's Ride Thread
                  Cardomain Page
                    yea it will there the same
                    PSN ID's:Tidashoni
                    1992 Accord EX Coupe
                    My FS Thread
                    Not so DD 2013 Subaru Impreza WRX STI
                    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
                      Kool! Thanks
                      CD7 H22
                      CB7 H22
                      Cardomain Page
                        Originally posted by 407accord
                        If you tighten the fitv while cold what will happen?
                        let me try this again
                        V6 POOOWAAAA
                        lol, a buick.
                          Wanted to revive this...I've been having the up down idle problem myself.
                          I followed all said repairs...idle still went up and down.
                          So the culprit? The idle was set too high, turned that screw down and that fixed it. I followed the recommended repair...and the idle was still too low with the IACV plugged in. Raised it a hair...now steady at 900, 700 after it settles.
                          Still...I would not rule out completely all that cleaning...my IACV did need some cleaning on the screen...and I already regularly clean my TB...that alone can cause idle issues.
                          I did also screw in the other valve...but it didn't change anything on the idle.
                          ____
                            So you have the A6 manifold then, cuz if I'm mistaken the air boost only came with the A6?
                            Proud owner of the only JJDM full 2.5" catback exhaust!
                              bringing this thread back because i found it extremely helpful today since i have been having problems with my idle the past couple of weeks so i pulled all of the said items and cleaned them with carb cleaner and replaced i also changed my PCV valve and i learned my intake manifold coolant lines had been bypassed so i bought new line and reran everything and now everything is A-OK
                                just like to say again...another likely culprit is idle screw...mine backed out 3 times in like 2 months
                                ____
