Old 05-06-2014, 02:01 AM   #1
cb9_marty
CB7tuner Member
cb9_marty is cool... so far.
temperature gauge staying on cold.
My temp gauge will only go up a qtr of the way when im stopped. When I get on the freeway it will stay all the way down or even below the Cold. Just recently started doing this, before it would stay at half way like normal, would changing the thermostat fix the problem?
cb9_marty is offline   Reply With Quote
Old 05-06-2014, 02:09 AM   #2
ninjawagon
Newcomer
ninjawagon is cool... so far.
Sounds like a slow opening thermostat.
ninjawagon is offline   Reply With Quote
Old 05-06-2014, 02:23 AM   #3
PhatAccord
CB7tuner Member
PhatAccord is cool... so far.
Send a message via AIM to PhatAccord
the "coolant temperature gauge sender" may be faulty. its what sends the signal for the needle position in the gauge cluster.
http://techautorepairs.com/images/acfanswitch.gif
PhatAccord is offline   Reply With Quote
Old 05-06-2014, 11:58 AM   #4
Sordz
CB7tuner Member
Sordz is cool... so far.
Sounds like you either don't have a thermostat in the car or its stuck open.
Sordz is offline   Reply With Quote
Old 05-06-2014, 03:02 PM   #5
cb9_marty
CB7tuner Member
I think ill change the thermostat first c if that wrks if not I will change the coolant temp gauge sender. Thanx yall
Old 05-10-2014, 10:10 PM   #6
PhatAccord
CB7tuner Member
any update?
Old 05-12-2014, 01:43 AM   #7
cb9_marty
CB7tuner Member
Quote:
Originally Posted by PhatAccord View Post
any update?
Not yet. . Still only goin up a qtr of the way, haven't got around to changing the thermostat
Old 05-20-2014, 07:47 PM   #8
spiderpig
CB7tuner Member
spiderpig is cool... so far.
Change the dang T-stat it takes like no time or skill at all lol
spiderpig is offline   Reply With Quote
Old 05-22-2014, 10:12 PM   #9
marvin75
CB7tuner Member
marvin75 is cool... so far.
yeah takes like 5 minutes. don't let the parts guy talk you into a 195 stat though stay with the stock temp
marvin75 is offline   Reply With Quote
Old 05-23-2014, 03:54 PM   #10
AccJacek
Newcomer
AccJacek is cool... so far.
Are You change thermostat?
Other question did You do something with gouges? i have o posit problem where all the time gouge for water temp show max reason was damaged one very thin electrical cable on gouge.
When You tighten or untighten must be very careful with screw keeping gouge on electrical plate..
AccJacek is offline   Reply With Quote
Old 05-24-2014, 01:06 AM   #11
v8vega355
CB7tuner Member
v8vega355 is cool... so far.
when driving down the freeway if your temp is sitting on cold and the heater is really hot then you might be looking at something electrical. if the heater sucks then thermostat is bad.
v8vega355 is offline   Reply With Quote
Tags
cb9 , help me , temperature , thermostat
