Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 06-07-2017, 11:21 AM   #1
h22sparkle
CB7tuner Member
h22sparkle may have said something they shouldn't have...
How to distinguish the different kseries motors
I'm looking for a k series motor to swap out of my sister. The only thing is I don't want to swap my si civic motor out for a slower one.
Now I've heard and seen on the internet that you can swap out the motor for a tsx jdm motor which has more torque but here's the thing.
The k24 engines vary in hp and they really don't show nothing on the blocks except k24 how can I distinguish each one from the one that I actually need?
h22sparkle is offline   Reply With Quote
Old 06-07-2017, 01:12 PM   #2
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
The engine ID stamp should be on the right side, near the starter. Wikipedia has good details on the output of each engine.
__________________
deevergote is offline   Reply With Quote
Old 06-07-2017, 01:59 PM   #3
CyborgGT
CB7tuner Member
CyborgGT is cool... so far.
Also, for a K24A2-spec K24A, "RBB" will be stamped on the head near the exhaust ports.
__________________
Slowly but surely... and gunning for that NA list!
Old 06-07-2017, 05:31 PM   #4
h22sparkle
CB7tuner Member
Okay so all I have to look for is the rbb on the exhaust manifold?
Old 06-07-2017, 05:58 PM   #5
h22sparkle
CB7tuner Member
I've been doing some digging and a old school pal of mine told me aside from the rbb stamped near the exhaust ports that there is no egr by the waterneck and if it says raa that that's out of an accord and don't buy it.
Old 06-07-2017, 09:30 PM   #6
'93CB7Ex
Gold Member
'93CB7Ex seems to have made some friends!
yea k24 with egr = trash. you want an RBB k24a2 from 04-08 tsx. they revised it in 2006 and had hotter cams/pistons etc. thats the one you want but the other will work too.
__________________
'93CB7Ex is offline   Reply With Quote
Old 06-08-2017, 12:56 AM   #7
h22sparkle
CB7tuner Member
Quote:
revised it how? in what way? let me get some details.
Old 06-08-2017, 05:44 AM   #8
Raf99
Gold Member
Raf99 is very helpful Raf99 is very helpful
They used a more aggressive cam with larger exhaust (i think), basically just a more aggressive head on the engine which resulted in more ccm flow. There were ECU changes too with VTEC engagment, etc.
https://en.wikipedia.org/wiki/Honda_K_engine#K24
20042005 Acura TSX
10.5:1
200 hp; 150 kW @ 6800 RPM
166 lbft (225 Nm) @ 4500 RPM
20062008 Acura TSX[3]
10.5:1
205 hp (153 kW) @ 7000 RPM
170.5 lbft (231 Nm) @ 4500 RPM
Old 06-09-2017, 11:03 AM   #9
CyborgGT
CB7tuner Member
Quote:
On the head, near the manifold.
__________________
Old 06-14-2017, 01:00 AM   #10
mjsstanley
CB7tuner Member
mjsstanley is cool... so far.
I still say the easiest way is to pop the valve cover off and look at the rocker assembly. My TSX block is stamped RAA on the side but has K24a2 in the front. Has oil squirters so I was able to confirm but rocker assembly is a definite way to tell.
IMO, you're not gonna notice too much of a difference going from a K20z3 to K24a2 in stock form.
mjsstanley is offline   Reply With Quote
Old 06-15-2017, 09:11 PM   #11
'93CB7Ex
Gold Member
look for RBB. thats the good shit.
__________________
