Old 04-23-2014, 02:16 AM   #1
cb9_marty
cb9_marty is cool... so far.
squeaking noise when making turns
Pretty much everytime I make a turn left or right I can hear some type of squeaking, not sure if it's coming directly from the steering wheel or not. When I turn the wheel while in one spot there is no noise only while im in motion. Any ideas what it might be? Thanx.
cb9_marty is offline   Reply With Quote
Old 04-23-2014, 03:49 PM   #2
anavrin351
anavrin351 is cool... so far.
The bushings on the upper control arm?
anavrin351 is offline   Reply With Quote
Old 04-23-2014, 08:01 PM   #3
SunkistCB7
SunkistCB7 is cool... so far.
I'm sure you already have.. Have you checked your brakes/rotor?
SunkistCB7 is offline   Reply With Quote
Old 04-24-2014, 12:02 AM   #4
cb9_marty
Lol actually i have not but im pretty sure I needa change them cuz recently started to hear some squeaking from them
Old 04-24-2014, 12:20 AM   #5
cb9_marty
Maybe..would I just have to replace them to find out if thats it or?
Old 04-24-2014, 01:40 AM   #6
RaiderCb7
RaiderCb7 is cool... so far.
I took mine to les schwab the other day for the same problem, and for pulsing when I brake. They diagnosed a tie rod on one side and bushings on the other that are worn and need replaced. My car hit 290k miles today. If you take it to them they will diagnose and quote your problem for free. Then chose to fix it yourself or take your quote somewhere else and have them check your problem for free and compare them.
RaiderCb7 is offline   Reply With Quote
Old 04-24-2014, 02:28 AM   #7
91cbkevinlx
91cbkevinlx is cool... so far.
my friend had that issue... it was his lower ball joint
91cbkevinlx is offline   Reply With Quote
Old 04-24-2014, 09:48 AM   #8
accordmaniac
accordmaniac is cool... so far.
Send a message via AIM to accordmaniac
I recently had same problem.
Front Knucle lower ball joint.
1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
accordmaniac is offline   Reply With Quote
Old 04-24-2014, 11:29 AM   #9
SunkistCB7
Sounds like ball joints are the consensus.. but I'm not sold, any other symptoms? (predominantly on bumpy roads.. on smooth pavement.. only during beginning of drive.. or after you've been driving awhile?)
Old 04-24-2014, 02:38 PM   #10
cb9_marty
Thanx everybody, ima have to go get it diagnosed and hopefully I can do it myself
Old 04-24-2014, 02:41 PM   #11
cb9_marty
Pretty much whenever I make a turn, when its a long curve it'll do it the whole time doesn't really matter how long I've been driving it or not.
Old 04-24-2014, 02:46 PM   #12
cb9_marty
Ok Thanx man, did u do urs urself? I noticed when I get to 65ish mph my car starts vibrating too, I'm hoping thats just because of my bad tires tho.
Old 04-24-2014, 04:29 PM   #13
RaiderCb7
they quoted me $500. I haven't got it done yet. Im gonna research the parts and possibly get a second opinion. I replaced my front tires which were almost bald and the problem almost went completely away. So my plan of action is to get it checked out at a different shop and see what they find wrong.
Old 04-24-2014, 06:16 PM   #14
SunkistCB7
Not sure how mechanically inclined you are, but this might help you or others..
"Quick Testing Balljoints/ Tie rods"-Courtesy of wikihow (w/ pictures)
Alot of the time shops will lift the car up and do this exact test. Others will try to shimmy them with a crowbar which always seemed sketch to me, but I guess these chassis parts should be strong enough. I was going to list steps.. but there's a thread already..
And good luck, I'm sure you can do the job yourself its a PITA but most autoparts stores have rental tools specifically for this.
Old 04-24-2014, 07:17 PM   #15
cb9_marty
Forsure man thanx a lot, ima try checking them tomorrow.. we'll see how that goes
Old 05-12-2014, 01:39 AM   #16
cb9_marty
Update.. posted a video of what it was doing on the cb7tuner group on Facebook and i just needed ps fluid. Problem seems to be solved.. still wanna change my tire rod ends and get alignment cuz im shaking when I get to around 60-65mph
Old 05-12-2014, 01:11 PM   #17
Accord problems
Location: THE HIPPIE STATE WHERE EVERY ONE DRIVE A PRIUS... NORTHERN CALIFORNIA *facepalm*
Accord problems is cool... so far.
it can also be as simple as a tire weight that got throughout of balance.
Accord problems is offline   Reply With Quote
Old 05-12-2014, 03:12 PM   #18
ninjawagon
ninjawagon is cool... so far.
I second this being as it MPH related and pretty specific. Every 5k or so you should always get you wheels and tire re-balanced to avoid running into this issue.
ninjawagon is offline   Reply With Quote
Old 05-13-2014, 05:44 PM   #19
cb9_marty
Oh ya I wanna get new tires as well im sure that will help a lot as well. Thanxguys
Old 05-13-2014, 06:52 PM   #20
tommi
Accord of the Month: August 2011
tommi seems to have made some friends!
my squeak when turning on my coupe was from the ps system. never did fix it tho someone elses prob now lol
(125)Transactions and counting
tommi is offline   Reply With Quote
cb9 , squeaky , turning
